Originally posted by alexbk66
View Post
AmbientWeather and Ecowitt - Local protocol (no Cloud)
This is a sticky topic.
Ver 4.0.2.20 (BETA) - Added Min/Max temperatures
Notes:
1. Some providers have Min/Max temperatures already, then use it
2. Only for today (will add "yesterday" later)
3. Min/Max reset at 00:01 (may make configurable)
4. If plugin is restarted - Min/Max reset (may save min/max for restart later)
5. Not really tested, please verify.
[UPDATE]
Ver 4.0.2.23 (BETA) - Keep Min/Max temperatures for plugin restart
- Likes 1
Hey alexbk66 I have your latest beta installed. Doesn't seem like the max temperature (for PWS) is working properly. See attached photos. One is my HomeSeer weather station device min/max values and the other is a picture of my Ambient Weather Station (2000) console. The max should be close to the current weather condition. These were both taken at around 8:50am. The Max is still reading yesterday's high.
Originally posted by begunfx View PostDoesn't seem like the max temperature (for PWS) is working properly. The max should be close to the current weather condition. These were both taken at around 8:50am. The Max is still reading yesterday's high.
I started a new thread as it's not Ecowitt specific https://forums.homeseer.com/forum/hs...rking-properly
Originally posted by alexbk66 View PostI started a new thread as it's not Ecowitt specific https://forums.homeseer.com/forum/hs...rking-properly
I have set up my Ambient 2000 weather station with your plugin and everything is working great, except it's not creating a device for the soil moisture. I selected the Ambient Weather Local as the device. I see the reading for soilhum1 coming in on the HS log. I have tried deleting the PWS and recreating it several times, but it doesn't help. I'm running version 4.0.2.37.
[1531] Back Yard: (AmbientWeatherLocal) soilhum1 = 7
Originally posted by Bruceg View PostI have set up my Ambient 2000 weather station with your plugin and everything is working great, except it's not creating a device for the soil moisture. I selected the Ambient Weather Local as the device. I see the reading for soilhum1 coming in on the HS log. I have tried deleting the PWS and recreating it several times, but it doesn't help. I'm running version 4.0.2.37.
It's using different keyword, normally it's "soilmoisture"
As I said before, I create HS features (for which data is not always available) only when data is available from the provider. In your case hourlyrainin is 0, so the Precipitation hourly device will be created when it starts raining.
I know it may be inconvenient sometimes, but I don't want to create HS devices unnecessary, because not every Ecowitt reports hourlyrainin.
As always thanks for your time and consideration.
I understand the issue with creating all the devices regardless if they are being used. The problem I'm running into is I've had about 14 inches of rain since October and have yet to see the hourly device be created. We don't get a lot of rain in Los Angeles, and I now might have to wait up to a year before I have another chance. Would it be possible to list all the devices that don't automatically get created and have the option to select them and have them manually created? Perhaps in each location's setting page?
Can you just poor some water on the sensor?
