AmbientWeather and Ecowitt - Local protocol (no Cloud)
This is a sticky topic.
    #61
    Looks like devices are all created but I did notice on some of the Precipitation Daily values, after midnight they show Unknown not 0. It stating raining here again so I can get you a screen shot at this time.
      #62
      Thank you, also can you get the data from the log when it shows Unknown - what does it report?
        #63
        Okay, here is a screen shot of the AK Weather Devices created for the AmbientWeather WS-2000 console using local mode.. I have also included the data stream so you can see what was sent.
        Lightning is showing as Unknown because we lost power early in the morning so that might be okay because that information is not in the datastream.
        Precipitation Weekly should be showing 0 because Sunday starts a new week (at least here in the US) but it's still showing last weeks total.
        Precipitation Event and Precipitation Daily did not reset to 0 after midnight but the data stream shows zero.
Name:	Screen Shot 07-18-21 at 08.30 AM 001.PNG
Name:	Screen Shot 07-18-21 at 08.30 AM.PNG
        [ATTACH]n1484688[/ATTACH]
          #64
          Thank you, so obviously I ignore zero values, need to check
            #65
            Ver 4.0.0.83 - AmbientWeather Local - reset daily/weekly precipitation
              #66
              Installed the new update and the values did go to Zero. Unfortunately, they stayed at zero even after a little bit of rain this morning. Data stream shows 0.012 rain this morning but Precipitation Week and Day still show Zero
                #67
                The precipitation display precision is one decimal place, you can change it in the device Status/Control/Graphics settings
                  #68
                  Ver 4.0.0.88 - a few fixes
                    #69
                    Ver 4.0.1.35 (BETA)
                    - Added Ecowitt and AmbientWeather Local battery devices
                    - added AQICN exception handlers
                    - refactored Location renaming
                    - improved config screens usability
                      #70
                      Hi Alex.
                      PMI AQI is not functioning correctly and appears to be containing a ?.
                      Click image for larger version  Name:	Capture2 - Copy.PNG Views:	0 Size:	24.9 KB ID:	1506709
                      Click image for larger version  Name:	DeviceDetail - Copy.PNG Views:	0 Size:	22.6 KB ID:	1506710
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) Waiting for connection... 0.0.0.0:7778
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) model = HP2553BC_Pro_V1.7.4
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) freq = 915M
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tf_batt1 = 1.58
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25batt1 = 5
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilbatt3 = 1.4
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilbatt2 = 1.1
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt4 = 0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt3 = 0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt2 = 0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt1 = 0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) wh25batt = 0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) wh80batt = 3.28
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tf_ch1 = 44.8
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25_avg_24h_ch1 = 8.3
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25_ch1 = 7.0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilmoisture3 = 45
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilmoisture2 = 22
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity4 = 55
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp4f = 62.1
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity3 = 65
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp3f = 72.0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity2 = 73
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp2f = 72.3
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity1 = 70
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp1f = 73.0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) uv = 0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) solarradiation = 0.24
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) yearlyrainin = 1.925
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) monthlyrainin = 0.004
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) weeklyrainin = 0.008
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) dailyrainin = 0.000
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) hourlyrainin = 0.000
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) eventrainin = 0.000
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) rainratein = 0.000
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) maxdailygust = 7.2
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windgustmph = 1.3
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windspdmph_avg10m = 0.0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windspeedmph = 0.0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) winddir_avg10m = 35
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) winddir = 22
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity = 66
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tempf = 47.7
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) baromabsin = 29.823
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) baromrelin = 29.823
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidityin = 46
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tempinf = 72.0
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) dateutc = 2021-11-06+22:13:31
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) stationtype = EasyWeatherV1.5.9
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) POST /data/report/ HTTP/1.1
                      HOST: 192.168.0.3
                      Connection: Close
                      Content-Type: application/x-www-form-urlencoded
                      Content-Length: 767
                      PASSKEY = 11001100101010111001110101010
                      11-06-2021 18:13:29 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) Connected!
                      Sysinfo:
                      Date/time=2021-11-06 18:22:06 Eastern Daylight Time
                      Version=HS4 Standard Edition 4.2.5.0 (Windows)
                      License=Registered
                      Confguration File=C:\Program Files (x86)\HomeSeer HS4\Data\HomeSeerData.json
                      In Virtual Machine=No MFG: intel corporation
                      Antivirus=Windows Defender
                      OS=Microsoft Windows 10 Home - Work Station
                      OS Version=10.0.19043
                      Uptime=0 Days 0 Hours 27 Minutes 41 Seconds
                      Lan IP=192.168.0.3 (servername)
                      Device Count=508
                      Event Count=41
                      Processor:=Intel64 Family 6 Model 78 Stepping 3 at 2.15 GHz
                      Modules/Threads=135 Modules, 62 Threads
                      Available Threads=1023
                      System Load=165 Processes, 17% Load
                      Free/Total Memory=12.29 GBytes / 15.89 GBytes (77% free)
                      Free/Total Virtual Memory=14.32 GBytes / 18.27 GBytes (78% free)
                      HomeSeer Memory Used=128 Mbytes
                      Plugin Memory Used=4 EXE Plug-Ins using 149 Mbytes
                      Plugins Installed=AK Weather 4.0.1.64,HS MyQ 4.0.7.0,Z-Wave 3.0.7.0,Z-Wave UI 1.0.0.0
                        #71
                        Originally posted by MikeO3 View Post
                        Hi Alex.
                        Hi Mike, what exactly do you mean by "not functioning correctly"? The value is correct? Or you mean it should be 7?
                        The question mark there shows that I'm not sure about the units.
                        Can you please provide screenshot of the mobile app or EasyWeather showing the readings
                          #72
                          BTW Mike, I updated some icons, so you should remove all HS devices (except for the root and CTRL) - after restarting the plugin they will be re-created
                            #73
                            Because of the ? the icon is not represented correctly against the status. Also, the value posted is the 24 avg it appears and not the current reading.
                            [1591] HP2553_7778: POST /data/report/ HTTP/1.1 HOST: 192.168.0.3 Connection: Close Content-Type: application/x-www-form-urlencoded Content-Length: 767 PASSKEY=XXXXXXXXXXXXXXXXXXXXXX&stationtype=EasyWeatherV1.5.9 &dateutc=2021-11-07+00:53:33&tempinf=71.6&humidityin=46&baromrelin=29.797&bar omabsin=29.797&tempf=46.4&humidity=66&winddir=37&winddir_avg 10m=6&windspeedmph=0.0&windspdmph_avg10m=1.1&windgustmph=2.0 &maxdailygust=7.2&rainratein=0.000&eventrainin=0.000&hourlyr ainin=0.000&dailyrainin=0.000&weeklyrainin=0.008&monthlyrain in=0.004&yearlyrainin=1.925&solarradiation=0.00&uv=0&temp1f= 72.5&humidity1=70&temp2f=71.8&humidity2=73&temp3f=71.2&humid ity3=65&temp4f=61.0&humidity4=53&soilmoisture2=22&soilmoistu re3=45&pm25_ch1=14.0&pm25_avg_24h_ch1=9.7&tf_ch1=45.3&wh80batt=3.28&wh25batt=0&batt1=0&batt2=0&batt3= 0&batt4=0&soilbatt2=1.1&soilbatt3=1.4&pm25batt1=5&tf_batt1=1.56&freq=915M&model=HP2553BC_Pro_V1.7.4
                              #74
                              Thanks but that would cause all new device ref's (?) I'll take a look at the sets with another data source maybe.
                                #75
                                Yeah, it will be new RefId. That's the reason I prefer using device address, not ID (discussed here https://forums.homeseer.com/forum/hs...53#post1506753)
                                Regarding showing the 24hr avg - I need to check. I think I show max of pm25_ch1 and pm25_avg_24h_ch1...
