AmbientWeather and Ecowitt - Local protocol (no Cloud)
This is a sticky topic.
    #76
    That will have to a be conversion project undertaken during the holiday break!
    Do let me know if you need any data or testing.
      #77
      Ver 4.0.1.76 - AmbientWeather Local - fix PM2.5
        #78
        Has it pushed up yet? It has not been available on refresh.
          #79
            #80
            I have it now. Strange. Anyway...
            The value 9.0? is still getting caught in the catchall not rendering the proper graphic. Sorry, new value between captures but same result.
Name:	Capture1 - Copy.PNG
Name:	Capture - Copy.PNG
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) Waiting for connection... 0.0.0.0:7778
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) model = HP2553BC_Pro_V1.7.4
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) freq = 915M
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tf_batt1 = 1.54
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilbatt3 = 1.4
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25batt1 = 5
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilbatt2 = 1.1
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt3 = 0
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt4 = 0
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt1 = 0
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt2 = 0
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) wh80batt = 3.28
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) wh25batt = 0
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tf_ch1 = 43.3
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25_avg_24h_ch1 = 9.3
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25_ch1 = 4.0
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilmoisture2 = 21
            11-07-2021 09:40:04 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilmoisture3 = 44
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity4 = 53
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp4f = 53.2
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity3 = 64
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp3f = 72.7
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity2 = 73
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp2f = 72.9
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity1 = 70
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp1f = 73.4
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) solarradiation = 33.39
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) uv = 0
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) yearlyrainin = 1.925
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) weeklyrainin = 0.000
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) monthlyrainin = 0.004
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) dailyrainin = 0.000
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) hourlyrainin = 0.000
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) eventrainin = 0.000
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) rainratein = 0.000
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) maxdailygust = 4.3
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windgustmph = 2.7
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windspdmph_avg10m = 1.1
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windspeedmph = 0.0
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) winddir = 287
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) winddir_avg10m = 8
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity = 72
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) baromabsin = 29.737
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tempf = 46.0
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) baromrelin = 29.737
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tempinf = 72.3
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidityin = 44
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) dateutc = 2021-11-07+14:40:05
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) stationtype = EasyWeatherV1.5.9
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) POST /data/report/ HTTP/1.1
            HOST: 192.168.0.3
            Connection: Close
            Content-Type: application/x-www-form-urlencoded
            Content-Length: 768
            PASSKEY = 101010101010101010
            11-07-2021 09:40:03 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) Connected!
            11-07-2021 09:36:35 AK Weather Info 2021-11-07 09:36:35 AK Weather ver. 4.0.1.76 (4.0.1.71) .NET Framework 4.8.4420.0
              #81
              Ver 4.0.1.77 - AWLocal pm25_ch1
              You need to delete air quality devices, so they will be re-created, sorry.
              I'm confused by the info you provided above - you have values 7.0, 9.0, 4.0, 9.3?
                #82
                Don't worry about the previous numbers because I didn't capture at the same instant in time. Values are current reading now and not "?".
Name:	2021-11-07 19.00.59 homeseer a93eb0961e5d - Copy.png
Name:	2021-11-07 19.00.31 www.ecowitt.net 840639657281 - Copy.png
                  #83
                  It's a shame they don't provide the AQI reading via API.
                    #84
                    Hey, alexbk66 I just ordered (and should receive today) the PM2.5 air quality sensor for my Ambient Weather Station. I am currently using Ambient Local to gather data from the weather station. How do I add the new sensor? Do I have to remove all of my current devices from Ambient Weather Local for it to be added or is there another way?
                    Thanks in advance for your help!
                      #85
                      New devices will be created automatically on discovery of the sensor information. No need to remove or change existing devices.
                        #86
                        Thanks, MikeO3
                          #87
                          It should appear automatically.
                            #88
                            Okay. I installed the PM2.5 outdoor air sensor and it is appearing fine on my ambient weather station console, but nothing is appearing in my Ambient Local device in HomeSeer. I tried disabling and enabling the plugin as well. No luck. Any ideas? I'm seeing no errors related to AK Weather in my logs either.
                              #89
                              Can you provide the logs?
                                #90
                                Btw, I'm running the latest 4.2.5.3 beta
