Originally posted by begunfx
View Post
AmbientWeather and Ecowitt - Local protocol (no Cloud)
This is a sticky topic.
Originally posted by alexbk66 View Post
[EDIT] Ver 4.0.2.17 (BETA)
Hello.
The update did not resolve the rounding up after a delete and recreate of the devices.
Code:1-18-2022 06:28:33 AK Weather Warning [1947] : Deleted device: id: 3121c6c07d.24, " - (ref 1947)" 1-18-2022 06:28:20 AK Weather Warning [1946] : Deleted device: id: 3121c6c07d.23, " - (ref 1946)" 1-18-2022 06:27:01 AK Weather Info 2022-01-18 06:27:01 AK Weather ver. 4.0.2.17 (4.0.2.15) .NET Framework 4.8.4420.0 1-17-2022 10:06:21 AK Weather Warning [1106] Ajax-EnvCan: Weather code 376 not found 1-17-2022 07:51:08 AK Weather Warning [0] : Parent wasn't created: id: 311aedbdb0.Alert, " - (ref 0)" 1-17-2022 07:21:01 AK Weather Warning [1106] Ajax-EnvCan: Weather code 378 not found 1-17-2022 06:50:22 AK Weather Warning [1106] Ajax-EnvCan: Weather code 377 not found 1-17-2022 06:50:08 AK Weather Info 2022-01-17 06:50:08 AK Weather ver. 4.0.2.16 (4.0.2.13) .NET Framework 4.8.4420.0
Originally posted by MikeO3 View PostHello. The update did not resolve the rounding up after a delete and recreate of the devices.
Also, https://forums.homeseer.com/forum/hs...-376-not-found
oops...Originally posted by alexbk66 View Post
Hmm, what's the moisture value in the log?
1.3 which is 1.3/1.5 = .86667 which is a correct battery value of status 87% rounded up.
Code:1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) Waiting for connection... 0.0.0.0:7778 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) model = HP2553BC_Pro_V1.7.4 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) freq = 915M 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tf_batt1 = 1.54 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25batt1 = 4 [B][COLOR=#c0392b]1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilbatt3 = 1.3 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilbatt2 = 1.3[/COLOR][/B] 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt4 = 0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt3 = 0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt2 = 0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) batt1 = 0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) wh25batt = 0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) wh80batt = 3.08 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tf_ch1 = 42.4 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25_avg_24h_ch1 = 6.5 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) pm25_ch1 = 3.0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilmoisture3 = 45 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) soilmoisture2 = 18 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity4 = 54 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp4f = 35.4 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity3 = 59 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp3f = 70.0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity2 = 71 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp2f = 67.8 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity1 = 70 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) uv = 0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) temp1f = 67.8 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) solarradiation = 0.00 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) monthlyrainin = 0.122 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) yearlyrainin = 5.067 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) weeklyrainin = 0.000 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) dailyrainin = 0.000 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) hourlyrainin = 0.000 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) eventrainin = 0.000 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) rainratein = 0.000 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windgustmph = 6.5 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) maxdailygust = 11.0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windspdmph_avg10m = 2.9 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) windspeedmph = 3.8 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) winddir_avg10m = 27 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) winddir = 316 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidity = 77 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tempf = 12.0 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) baromabsin = 29.534 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) baromrelin = 29.534 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) humidityin = 39 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) dateutc = 2022-01-18+12:17:55 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) tempinf = 71.2 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) stationtype = EasyWeatherV1.6.1 1-18-2022 07:17:56 AK Weather Info [1591] HP2553_7778: (AmbientWeatherLocal) HTTP = /1.1 HOST: 192.168.0.3 Connection: Close Content-Type: application/x-www-form-urlencoded Content-Length: 769
Not really, I mean I could work out min/max temperatures in my plugin, not sure if it's worth the effort though
Originally posted by begunfx View Post
Oh, I see. Do you mean by tracking the current temp and reporting the Min/Max? That would be cool. I would appreciate it if you did, but certainly up to you if you want to put the time into it.
[EDIT]
It's just not clear when it should reset? Max temp is kind of simple - start tracking from midnight. But what about min temp? It could be previous night, or the coming night - not obvious....
Originally posted by alexbk66 View PostIt's just not clear when it should reset? Max temp is kind of simple - start tracking from midnight. But what about min temp? It could be previous night, or the coming night - not obvious....
I would say they both need to reset at midnight local time to create a baseline of 0 for the day. That's the way Daily graphing works on ecowitt.net.
Not really reset to zero, but start tracking at midnight. So if at midnight it's 45F then start comparing the temp moving forward for min and max from there. If it goes down to 43F after midnight, then that's the new low and 45F would be the new high. If at 8am it becomes 72F, then 72F would be the new high and the low would be 43F etc. Start the cycle again at midnight.
- Likes 1
I've been reading and following along and I had a minor suggestion for the min/max temp.
Wouldn't it also be nice to also store a min/max for 'Yesterday'?
If I wake up at 7am and look at temps in the summer, I'd want to know how hot it was yesterday as well as how cold it got yesterday in the winter.Dan-O
HomeSeer contributor since summer 1999, yes 1999!
Originally posted by Dan-O View PostI've been reading and following along and I had a minor suggestion for the min/max temp.
[EDIT]
I just don't like multiplying devices unnecessary. So we want 4 devices for Min/Max (today and yesterday), also another 4 for the min/max time?
I could show the time together with the temperature (i.e. 15C 01:00 AM)
But I guess with the new feature Selecting devices to display it shouldn't be too much of a problem?
