Tim, I always prefer to implement stuff asap if possible, and forget about it 😀
Davis Instruments WeatherLink
This is a sticky topic.
Originally posted by alexbk66 View Post
Any luck?
Few devices were created. Most appear missing (Outdoor ISS.) Settings, device screenshots, and trace logs are attached.
Thoughts?image_106837.txt
Originally posted by avpman View Post
the text file already attached above is trace log. do not know why name was changed. click on linkAttached Files
Originally posted by alexbk66 View PostIt looks like you have some connectivity issues. But when connection works - the values should be set correctly.
Say you clear the log and restart the plugin, what happens?
Originally posted by alexbk66 View PostSo I guess, you entered the IP Address in wrong spot?
It should be "WeatherLinkLive IP Address", not "AirLink IP Address"
I switched the WLL to cabled instead of wiFi. Entered the new ip in the setup. Odd that even though I had IP in the wrong place it didn't throw an error in the log. In any event it's now working.
- Likes 1
