Originally posted by alexbk66
View Post
Davis Instruments WeatherLink
This is a sticky topic.
Originally posted by Pete View PostThank you Tim.
Davis console using the buffered serial cable that I purchased from Australia many many years ago.
Originally posted by brientim View PostAcknowledged, and I will as soon as the App Store makes it available
I'm wondering how to implement the sensors HS devices? Problem with Davis is that each sensor is a separate device, but I don't want to create a separate root for each sensor, I prefer having one root per PWS.
Originally posted by alexbk66 View Post
How's ver 4.0.0.85?
4.0.0.85 I have not really had much chance to monitor this however, it appears that not all devices are updating.
Davis is correct in the world of meteorology but whether it is relevant to Home Automation is another thing.
Not all device are relevant in HomeSeer and therefore I agree that splitting device is not really required and only bloats the number of devices with no real return.
Tim
Code:[1827] 1 Victoria, Australia,: /current/12345: {"sensors":[{"lsid":227171,"data":[{"battery_voltage":4932,"wifi_rssi":null,"network_error":null,"ip_v4_gateway":"1.1.1.1","bluetooth_version":null,"bgn":null,"firmware_version":1596147041,"local_api_queries":296537,"rx_bytes":573941223,"health_version":1,"radio_version":621020416,"ip_address_type":1,"link_uptime":563832,"input_voltage":4690,"tx_bytes":949514558,"ip_v4_netmask":"255.255.255.0","rapid_records_sent":386394,"uptime":966082,"touchpad_wakeups":69,"ip_v4_address":"1.1.1.2","bootloader_version":1550707628,"espressif_version":1534381024,"dns_type_used":null,"network_type":2,"ts":1627209000}],"sensor_type":504,"data_structure_type":15},{"lsid":256775,"data":[{"rx_state":0,"wind_speed_hi_last_2_min":8,"hum":74.1,"wind_dir_at_hi_speed_last_10_min":291,"wind_chill":49.7,"rain_rate_hi_last_15_min_clicks":0,"thw_index":49.7,"wind_dir_scalar_avg_last_10_min":309,"rain_size":2,"uv_index":null,"wind_speed_last":2,"rainfall_last_60_min_clicks":0,"wet_bulb":45.6,"rainfall_monthly_clicks":115,"wind_speed_avg_last_10_min":3.06,"wind_dir_at_hi_speed_last_2_min":286,"rainfall_daily_in":0,"wind_dir_last":360,"rainfall_daily_mm":0,"rain_storm_last_clicks":4,"tx_id":2,"rain_storm_last_start_at":1627114441,"rain_rate_hi_clicks":0,"rainfall_last_15_min_in":0,"rainfall_daily_clicks":0,"dew_point":42.2,"rainfall_last_15_min_mm":0,"rain_rate_hi_in":0,"rain_storm_clicks":0,"rain_rate_hi_mm":0,"rainfall_year_clicks":1367,"rain_storm_in":0,"rain_storm_last_end_at":1627203661,"rain_storm_mm":0,"wind_dir_scalar_avg_last_2_min":315,"heat_index":50.1,"rainfall_last_24_hr_in":0,"rainfall_last_60_min_mm":0,"trans_battery_flag":0,"rainfall_last_60_min_in":0,"rain_storm_start_time":null,"rainfall_last_24_hr_mm":0,"rainfall_year_in":10.76378,"wind_speed_hi_last_10_min":14,"rainfall_last_15_min_clicks":0,"rainfall_year_mm":273.4,"wind_dir_scalar_avg_last_1_min":316,"temp":50.1,"wind_speed_avg_last_2_min":2.31,"solar_rad":null,"rainfall_monthly_mm":23,"rain_storm_last_mm":0.8,"wind_speed_avg_last_1_min":2.31,"thsw_index":null,"rainfall_monthly_in":0.9055118,"rain_rate_last_mm":0,"rain_rate_last_clicks":0,"rainfall_last_24_hr_clicks":0,"rain_storm_last_in":0.031496063,"rain_rate_last_in":0,"rain_rate_hi_last_15_min_mm":0,"rain_rate_hi_last_15_min_in":0,"ts":1627209311}],"sensor_type":44,"data_structure_type":10},{"lsid":227174,"data":[{"rx_state":0,"wind_speed_hi_last_2_min":8,"hum":74.1,"wind_dir_at_hi_speed_last_10_min":291,"wind_chill":50.6,"rain_rate_hi_last_15_min_clicks":0,"thw_index":50.3,"wind_dir_scalar_avg_last_10_min":309,"rain_size":2,"uv_index":0,"wind_speed_last":2,"rainfall_last_60_min_clicks":0,"wet_bulb":46.3,"rainfall_monthly_clicks":155,"wind_speed_avg_last_10_min":3.06,"wind_dir_at_hi_speed_last_2_min":286,"rainfall_daily_in":0,"wind_dir_last":360,"rainfall_daily_mm":0,"rain_storm_last_clicks":4,"tx_id":1,"rain_storm_last_start_at":1627114381,"rain_rate_hi_clicks":0,"rainfall_last_15_min_in":0,"rainfall_daily_clicks":0,"dew_point":42.9,"rainfall_last_15_min_mm":0,"rain_rate_hi_in":0,"rain_storm_clicks":0,"rain_rate_hi_mm":0,"rainfall_year_clicks":1391,"rain_storm_in":0,"rain_storm_last_end_at":1627203661,"rain_storm_mm":0,"wind_dir_scalar_avg_last_2_min":315,"heat_index":50.6,"rainfall_last_24_hr_in":0,"rainfall_last_60_min_mm":0,"trans_battery_flag":0,"rainfall_last_60_min_in":0,"rain_storm_start_time":null,"rainfall_last_24_hr_mm":0,"rainfall_year_in":10.952756,"wind_speed_hi_last_10_min":14,"rainfall_last_15_min_clicks":0,"rainfall_year_mm":278.2,"wind_dir_scalar_avg_last_1_min":316,"temp":50.9,"wind_speed_avg_last_2_min":2.31,"solar_rad":0,"rainfall_monthly_mm":31,"rain_storm_last_mm":0.8,"wind_speed_avg_last_1_min":2.31,"thsw_index":48.3,"rainfall_monthly_in":1.2204725,"rain_rate_last_mm":0,"rain_rate_last_clicks":0,"rainfall_last_24_hr_clicks":0,"rain_storm_last_in":0.031496063,"rain_rate_last_in":0,"rain_rate_hi_last_15_min_mm":0,"rain_rate_hi_last_15_min_in":0,"ts":1627209311}],"sensor_type":46,"data_structure_type":10},{"lsid":227173,"data":[{"temp_in":71.9,"heat_index_in":69.4,"dew_point_in":43.2,"ts":1627209311,"hum_in":35.6}],"sensor_type":243,"data_structure_type":12},{"lsid":227172,"data":[{"bar_absolute":29.611,"bar_sea_level":29.713,"bar_offset":-0.001,"bar_trend":0.029,"ts":1627209311}],"sensor_type":242,"data_structure_type":12},{"lsid":227177,"data":[{"rx_state":0,"moist_soil_2":15,"moist_soil_1":7.9,"moist_soil_4":null,"moist_soil_3":40.4,"wet_leaf_2":null,"wet_leaf_1":0.1,"tx_id":4,"temp_1":46.5,"temp_2":45.7,"trans_battery_flag":0,"temp_3":46.8,"temp_4":null,"ts":1627209311}],"sensor_type":56,"data_structure_type":12},{"lsid":359831,"data":[{"hum":62.8,"pm_10_3_hour":2.0236752,"pm_10_24_hour":0.88670665,"pm_2p5_1_hour":0.06854936,"aqi_nowcast_val":2,"aqi_type":"Australia NEPM AQI","heat_index":51.8,"pm_2p5_nowcast":0.6220705,"pm_2p5_24_hour":0.4997082,"pm_1":0,"pct_pm_data_nowcast":100,"pct_pm_data_24_hour":100,"wet_bulb":45.5,"aqi_val":0,"aqi_desc":"Very Good","temp":52.8,"pm_2p5_3_hour":1.4934772,"pct_pm_data_3_hour":100,"last_report_time":1627209300,"aqi_nowcast_desc":"Very Good","aqi_1_hour_val":0,"pm_10_nowcast":1.0295537,"aqi_1_hour_desc":"Very Good","pm_10_1_hour":0.301231,"dew_point":40.5,"pm_10":0,"pct_pm_data_1_hour":100,"ts":1627209300,"pm_2p5":0}],"sensor_type":323,"data_structure_type":16},{"lsid":359830,"data":[{"wifi_rssi":-40,"network_error":null,"ip_v4_gateway":"1.1.1.1","internal_free_mem_chunk_size":46300,"record_backlog_count":0,"firmware_version":1603306935,"rx_packets":21643,"internal_used_mem":126392,"application_sha":"a3000a02f......","packet_errors":10,"internal_free_mem":87056,"dropped_packets":63844,"local_api_queries":47230,"link_uptime":280713,"total_used_mem":760800,"health_version":2,"ip_address_type":1,"record_write_count":1246,"application_version":"v1.0.4","tx_packets":62857,"ip_v4_netmask":"255.255.255.0","uptime":280716,"internal_free_mem_watermark":66984,"ip_v4_address":"1.1.1.3","bootloader_version":527991452,"total_free_mem":1180384,"dns_type_used":null,"ts":1627209000,"record_stored_count":1246}],"sensor_type":506,"data_structure_type":18}],"generated_at":1627209529,"station_id":12345}
Originally posted by brientim View Post4.0.0.85 I have not really had much chance to monitor this however, it appears that not all devices are updating.
It would be great to be able to disable the devices in the plugin we don't need or want. But I guess the amount of work required to do that is going to depend on how the plugin discovers/enumerates them. I'm ok with manually deleting them as long as they don't get recreated somehow. Either way, it's not a big deal for a person with only one station to monitor.
Originally posted by avpman View PostIt would be great to be able to disable the devices in the plugin we don't need or want. But I guess the amount of work required to do that is going to depend on how the plugin discovers/enumerates them. I'm ok with manually deleting them as long as they don't get recreated somehow. Either way, it's not a big deal for a person with only one station to monitor.
IMHO better option is to only create devices which users will actually use. I create HS devices only for data available from the provider.
One option is to create a config table listing already created devices with checkboxes to disable each device. But I'm not sure if it really worth the effort?
I do have "Minimal details level" switch per Location - so I just need to decide which devices belong to "Minimal details" group?
Any input is welcome.
And, yeah, manually deleted devices will be re-created on restart.
Originally posted by alexbk66 View PostPersonally I don't like selecting the devices in Weather plugins. Other plugin types don't have this "feature".
Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD="width: 404"]{[/TD] [TD="width: 87"]Required[/TD] [TD="width: 87"] [/TD] [/TR] [TR] [TD]"data":{[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "did":"001----",[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "ts":1627241193,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "conditions":[[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] {[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "lsid":227174,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "data_structure_type":1,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "txid":1,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "temp":49.4,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "hum":81.9,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "dew_point":44.1,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wet_bulb":46.4,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "heat_index":49.4,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_chill":49.4,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "thw_index":49.4,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "thsw_index":47.4,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_last":1.00,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_last":340,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_avg_last_1_min":0.87,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_scalar_avg_last_1_min":344,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_avg_last_2_min":1.18,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_scalar_avg_last_2_min":344,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_hi_last_2_min":3.00,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_at_hi_speed_last_2_min":336,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_avg_last_10_min":1.06,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_scalar_avg_last_10_min":340,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_hi_last_10_min":4.00,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_at_hi_speed_last_10_min":349,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_size":2,[/TD] [TD]No[/TD] [TD]This represents the netric tipping bucket[/TD] [/TR] [TR] [TD] "rain_rate_last":0,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_rate_hi":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_last_15_min":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_rate_hi_last_15_min":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_last_60_min":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_last_24_hr":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm_start_at":null,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "solar_rad":0,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "uv_index":0.0,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "rx_state":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "trans_battery_flag":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_daily":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_monthly":155,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_year":1391,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm_last":4,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm_last_start_at":1627114381,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm_last_end_at":1627203661[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] },[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] {[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "lsid":227177,[/TD] [TD="colspan: 2"]Soil/Moisture No but other may want for integration with irrigation and this is subjective limited users that would have this[/TD] [/TR] [TR] [TD] "data_structure_type":2,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "txid":4,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "temp_1":46.3,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "temp_2":46.0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "temp_3":45.9,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "temp_4":null,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "moist_soil_1":7.8,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "moist_soil_2":15.1,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "moist_soil_3":38.5,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "moist_soil_4":null,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wet_leaf_1":0.1,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wet_leaf_2":null,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rx_state":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "trans_battery_flag":0[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] },[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] {[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "lsid":256775,[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "data_structure_type":1,[/TD] [TD="colspan: 2"]This is a second Station and not required can be up to 8 Devices on a WLL[/TD] [/TR] [TR] [TD] "txid":2,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "temp":47.6,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "hum":83.8,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "dew_point":42.9,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wet_bulb":45.0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "heat_index":47.6,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_chill":47.6,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "thw_index":47.6,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "thsw_index":null,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_last":1.00,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_last":340,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_avg_last_1_min":0.87,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_scalar_avg_last_1_min":344,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_avg_last_2_min":1.18,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_scalar_avg_last_2_min":344,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_hi_last_2_min":3.00,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_at_hi_speed_last_2_min":336,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_avg_last_10_min":1.06,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_scalar_avg_last_10_min":340,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_speed_hi_last_10_min":4.00,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "wind_dir_at_hi_speed_last_10_min":349,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_size":2,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_rate_last":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_rate_hi":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_last_15_min":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_rate_hi_last_15_min":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_last_60_min":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_last_24_hr":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm_start_at":null,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "solar_rad":null,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "uv_index":null,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rx_state":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "trans_battery_flag":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_daily":0,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_monthly":115,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rainfall_year":1367,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm_last":4,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm_last_start_at":1627114441,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "rain_storm_last_end_at":1627203661[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] },[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] {[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "lsid":227173,[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "data_structure_type":4,[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "temp_in":69.5,[/TD] [TD]Yes[/TD] [TD]Inside Temp[/TD] [/TR] [TR] [TD] "hum_in":39.9,[/TD] [TD]Yes[/TD] [TD]Inside Humidity[/TD] [/TR] [TR] [TD] "dew_point_in":44.1,[/TD] [TD]No[/TD] [TD]Not relevant to inside[/TD] [/TR] [TR] [TD] "heat_index_in":67.5[/TD] [TD]No[/TD] [TD]Not relevant to inside[/TD] [/TR] [TR] [TD] },[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] {[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "lsid":227172,[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "data_structure_type":3,[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] "bar_sea_level":29.790,[/TD] [TD]Yes[/TD] [TD] [/TD] [/TR] [TR] [TD] "bar_trend":-0.009,[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] "bar_absolute":29.688[/TD] [TD]No[/TD] [TD] [/TD] [/TR] [TR] [TD] }[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD] ][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD]},[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD]"error":null[/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD]}[/TD] [TD] [/TD] [TD] [/TD] [/TR] [/TABLE]
Weatherlink Data
Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR="class: cke_show_border"] [TD="width: 721"] "sensors":[[/TD] [TD="width: 87"]Required[/TD] [/TR] [TR="class: cke_show_border"] [TD] {[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "lsid":227171,[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "data":[[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] {[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "battery_voltage":4930,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "wifi_rssi":null,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "network_error":null,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ip_v4_gateway":"",[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "bluetooth_version":null,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "bgn":null,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "firmware_version":1596147041,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "local_api_queries":301944,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "rx_bytes":583872205,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "health_version":1,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "radio_version":621020416,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ip_address_type":1,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "link_uptime":31922,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "input_voltage":4697,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "tx_bytes":969445229,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ip_v4_netmask":"25.0",[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "rapid_records_sent":400433,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "uptime":1001180,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "touchpad_wakeups":69,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ip_v4_address":"1",[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "bootloader_version":1550707628,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "espressif_version":1534381024,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "dns_type_used":null,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "network_type":2,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ts":1627244100[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] }[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] ],[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "sensor_type":504,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "data_structure_type":15[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] },[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] ],[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "sensor_type":46,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "data_structure_type":10[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] },[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] }[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] ],[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "sensor_type":243,[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "data_structure_type":12[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] },[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] {[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] }[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] ],[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "sensor_type":242,[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "data_structure_type":12[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] },[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] {[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "pm_2p5":0[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] }[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] ],[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "sensor_type":323,[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "data_structure_type":16[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] },[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] {[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "lsid":359830,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "data":[[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] {[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "wifi_rssi":-79,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "network_error":null,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ip_v4_gateway":"",[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "internal_free_mem_chunk_size":46300,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "record_backlog_count":0,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "firmware_version":1603306935,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "rx_packets":56814,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "internal_used_mem":126604,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "application_sha":"a30008",[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "packet_errors":10,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "internal_free_mem":86768,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "dropped_packets":13873,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "local_api_queries":52411,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "link_uptime":30186,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "total_used_mem":760992,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "health_version":2,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ip_address_type":1,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "record_write_count":1402,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "application_version":"v1.0.4",[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "tx_packets":30318,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ip_v4_netmask": "0",[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "uptime":315816,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "internal_free_mem_watermark":,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ip_v4_address":"",[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "bootloader_version":527991452,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "total_free_mem":1180108,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "dns_type_used":null,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "ts":1627244100,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "record_stored_count":1402[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] }[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] ],[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "sensor_type":506,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "data_structure_type":18[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] }[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] ],[/TD] [TD] [/TD] [/TR] [TR="class: cke_show_border"] [TD] "generated_at":1627244278,[/TD] [TD]No[/TD] [/TR] [TR="class: cke_show_border"] [TD] "station_id":6[/TD] [TD]No[/TD] [/TR] [/TABLE]
Daviis Airlink AQI
Code:[TABLE="border: 0, width: 0"] [TR="class: cke_show_border"] [TD="class: xl65"] [TABLE="width: 0"] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"data"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:{[/FONT][/COLOR] [/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Requiired[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"did"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]"001D0A100326"[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"name"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]"Hoppers Crossing AQI"[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]This is a subjective new device as disussed and for Local API is is different Device[/FONT][/COLOR][/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"ts"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]1627242608[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"conditions"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[[/FONT][/COLOR] [/FONT][/COLOR][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit]{ [/FONT][/COLOR][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"lsid"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]359831[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"data_structure_type"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]6[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"temp"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]53.1[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes if separate device[/FONT][/COLOR][/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"hum"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]67.4[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes if separate device[/FONT][/COLOR][/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"dew_point"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]42.6[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"wet_bulb"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]46.9[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"heat_index"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]52.3[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_1_last"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_2p5_last"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_10_last"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_1"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.00[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_2p5"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.00[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_2p5_last_1_hour"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.00[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_2p5_last_3_hours"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.00[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_2p5_last_24_hours"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.34[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_2p5_nowcast"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.01[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_10"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.90[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_10_last_1_hour"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.40[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_10_last_3_hours"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.34[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_10_last_24_hours"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.83[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pm_10_nowcast"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]0.39[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]No[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"last_report_time"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]1627242607[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pct_pm_data_last_1_hour"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]100[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pct_pm_data_last_3_hours"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]100[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pct_pm_data_nowcast"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]100[/FONT][/COLOR][COLOR=#666666][FONT=inherit],[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"pct_pm_data_last_24_hours"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]100[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD][COLOR=black][FONT=Calibri]Yes[/FONT][/COLOR][/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit]}[/FONT][/COLOR][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit]][/FONT][/COLOR][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit]},[/FONT][/COLOR][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit][COLOR=#4A4A4A][FONT=inherit]"error"[/FONT][/COLOR][COLOR=#666666][FONT=inherit]:[/FONT][/COLOR][COLOR=#777777][FONT=inherit]null[/FONT][/COLOR][/FONT][/COLOR][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD="class: xl65"][COLOR=#666666][FONT=inherit]}[/FONT][/COLOR][/TD] [TD] [/TD] [TD] [/TD] [/TR] [/TABLE] [/TD] [TD] [/TD] [TD] [/TD] [/TR] [/TABLE] [TABLE="class: Table, border: 0, cellpadding: 10, width: 668"] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"data"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:{ [/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Requiired[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"did"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]"001D0A100326"[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"name"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]"Hoppers Crossing AQI"[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]This is a subjective new device as disussed and for Local API is is different Device[/COLOR][/FONT][/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"ts"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]1627242608[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"conditions"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[ [/COLOR][/FONT][/FONT][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#666666]{ [/COLOR][/FONT][/FONT][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"lsid"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]359831[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"data_structure_type"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]6[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"temp"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]53.1[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes if separate device[/COLOR][/FONT][/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"hum"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]67.4[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes if separate device[/COLOR][/FONT][/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"dew_point"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]42.6[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"wet_bulb"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]46.9[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"heat_index"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]52.3[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_1_last"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_2p5_last"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_10_last"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_1"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.00[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_2p5"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.00[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_2p5_last_1_hour"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.00[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_2p5_last_3_hours"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.00[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_2p5_last_24_hours"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.34[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_2p5_nowcast"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.01[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_10"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.90[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_10_last_1_hour"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.40[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_10_last_3_hours"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.34[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_10_last_24_hours"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.83[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pm_10_nowcast"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]0.39[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]No[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"last_report_time"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]1627242607[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pct_pm_data_last_1_hour"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]100[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pct_pm_data_last_3_hours"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]100[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pct_pm_data_nowcast"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]100[/COLOR][/FONT][FONT=inherit][COLOR=#666666],[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"pct_pm_data_last_24_hours"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]100[/COLOR][/FONT][/FONT][/TD] [TD][FONT=Calibri][COLOR=black]Yes[/COLOR][/FONT][/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#666666]}[/COLOR][/FONT][/FONT][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#666666]][/COLOR][/FONT][/FONT][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#666666]},[/COLOR][/FONT][/FONT][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#4a4a4a]"error"[/COLOR][/FONT][FONT=inherit][COLOR=#666666]:[/COLOR][/FONT][FONT=inherit][COLOR=#777777]null[/COLOR][/FONT][/FONT][/TD] [TD] [/TD] [TD] [/TD] [/TR] [TR] [TD][FONT=Calibri][FONT=inherit][COLOR=#666666]}[/COLOR][/FONT][/FONT][/TD] [TD] [/TD] [TD] [/TD] [/TR] [/TABLE]
Originally posted by Pete View PostWould you consider an option in your new plugin to use serial data from the console via direct connection or a serial to Ethernet connection or using readable data from the Meteostick?
I implemented Meteobridge, but not Meteostick - I asked them if there's an API I can use. I always prefer to communicate with the manufacturer directly and use the official API if possible.
Sure Pete, I can consider anything having API - I don't like "unofficial" hacks.
I think WeatherLink Live (6100) is the best option for Local. But if you tell me exactly what you need - and will do the testing - sure I can do.
Just confirming that your plugin IS currently compatible with the WeatherLink Live 6100 before I buy the 6100.
