It looks like I can add heat_index, pm_2p5, pm_10.
What's pct_pm?
What's pct_pm?
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
{ "sensors":[ { "lsid":3....., "data":[ { "hum":82.4, -- "pm_10_3_hour":11.588649, -- "pm_10_24_hour":12.6041 95, --"pm_2p5_1_hour":8.806256, "aqi_nowcast_val":42, "aqi_type":"Australia NEPM AQI", "heat_index":42.9, -- "pm_2p5_nowcast":10.5957365, --"pm_2p5_2 4_hour":11.210443, "pm_1":3.5797102, --"pct_pm_data_nowcast":100, --"pct_pm_data_24_hour":100, "wet_bulb":40.5, "aqi_val":15, "aqi _desc":"Very Good", "temp":43.1, -- "pm_2p5_3_hour":10.257337, -- "pct_pm_data_3_h our":100, "last_report_time":1631821500, --"aqi_nowcast_desc":"Good", --"aqi_1_hour_val":35, --"pm_10_nowcast":11.969684, -- "aqi_1_ho ur_desc":"Good", --"pm_10_1_hour":10.120999, "dew_point":38.1, "pm_10":3.8115942, -- "pct_pm_data_1_hour":100, "ts":1631821500, "pm _2p5":3.8115942 } ], "sensor_type":323, [B]"data_structure_type":16[/B] }, { "lsid":3----, "data":[ { "wifi_rssi":-71, "network_error":null, "ip_v4_gateway":"192......", "inter nal_free_mem_chunk_size":46716, "record_backlog_count":0, "firmware_version":1603306935, "rx_packets":4556, "internal_used_m em":126264, "application_sha":"a3000a28", "packet_errors":0, "inter nal_free_mem":87092, "dropped_packets":5474, "local_api_querie s":55376, "link_uptime":410855, "total_used_mem":760620, "healt h_version":2, "ip_address_type":1, "record_write_count":1825, " application_version":"v1.0.4", "tx_packets":65473, "ip_v4_netm ask":"255.2,,,", "uptime":410858, "internal_free_mem_wate rmark":66372, "ip_v4_address":"192.1,,,,", "bootloader_vers ion":527991452, "total_free_mem":1180452, "dns_type_used":null, "ts":1631821500, "record_stored_count":1825 } ], "sensor_type":506, "data_structure_type":18
