Do you by chance have the NOAA Weather Buoys (NDBC) available?
    Originally posted by niewski View Post
    Alex - thanks for the killer support! The marine forecasts are working awesome!
    Do you by chance have the NOAA Weather Buoys available? https://www.ndbc.noaa.gov/station_pa...?station=45196
    I just found this - https://www.ndbc.noaa.gov/rt_data_access.shtml and https://www.ndbc.noaa.gov/docs/ndbc_web_data_guide.pdf
    Yes, this should work, when I have time.
    I need to finish Davis Instruments WeatherLink, then I will add NDBC
    Click image for larger version  Name:	National Data Buoy Center.png Views:	63 Size:	333.5 KB ID:	1487018
    Ver 4.0.0.94 - Added NOAA-NDBC (National Data Buoy Center)
    Click image for larger version  Name:	NDBC.jpg Views:	30 Size:	134.1 KB ID:	1487333
      You are amazing.
      I got my 2 buoys up and running.
      I noticed that the wave heights on the NOAA page are displayed in FT. In the plugins, I'm having them shown in M. What can I do to change it to ft?
        For units I use HS temperature setting (C/F), what's your set to?
Name:	Screenshot 2021-10-12 093852.png
          There's some inconsistency in the API - wave heights are in meters, but tides - in FT. I'll fix it.
Name:	Screenshot 2021-10-12 095842.png
            Click image for larger version  Name:	2021-10-11_21-56-17.png Views:	0 Size:	45.6 KB ID:	1501836
              Thanks! You know the Americans... Unfortunately, we struggle with a system based on base 10!
                Yeah, as I said, I need to convert from 'm' to 'ft' - I wasn't sure if it's a mistake in the documentation, apparaently not
                  Understood. Just put it there in case it would aid you in troubleshooting / confirmation. Thanks!
                    Ver 4.0.1.39 - NOAA-NDBC (National Data Buoy Center) units for tides and wave height
