Can_Weather - I don't seem to be able to get the drop down list of locations
    Originally posted by cd36 View Post
    I don't seem to be able to get the drop down list of locations that you guys are showing. Mine just says "Station list is empty" then underneath it I have a Can_Weather Station field where I can manually enter in a station. For example if I enter CPOY-AUTO, it does pull up Cypress River for me, but your previous screenshots are showing a drop down list, which I seem to be missing.
    cd36 Can you please give me your coordinates so I can test getting list of stations for your area
    Sent you a PM.
      Sent you a PM.
      It does work. I suggest re-creating location again.
      But I noticed that HS config pages keep the input info, so you must make sure you don't reuse (refresh) the Settings page, but make sure you open the Settings page every time.
      And just in case you may delete "C:\Program Files (x86)\HomeSeer HS4\Data\AKWeather\swob-xml_station_list_49.xx_-99.xx.json"
        Click image for larger version  Name:	2021-08-29.png Views:	0 Size:	105.3 KB ID:	1492234
        Thanks. Important information I forgot to mention, this is on a hometroller pi g1.
        I have deleted and remade the location several times, as well as make a second location in the plugin, it has never shown the list.
        ‚Äč
          May be try slightly different coordinates.
          And please try providing more info, i.e. enable Log for the location (straight when it's created).
          Post screenshots too.
            Date/time=8/29/2021 9:52:44 AM CDT
            Version=HomeSeer HS4 Pi Hub G1 Edition 4.2.0.0 (Linux)
            MONO Version=Mono JIT compiler version 6.12.0.122 (tarball Mon Feb 22 17:44:05 UTC 2021)
            License=Registered
            Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
            Uptime=2 Days 19 Hours 52 Minutes 36 Seconds
            Lan IP=192.168.10.123 (HS4PiV5)
            Device Count=138
            Event Count=7
            Plugins Enabled=Z-Wave:,Z-Wave UI:,HSBuddy:,AK Weather:
            Modules/Threads=81 Modules, 66 Threads
            Available Threads=398
            HomeSeer Memory Used=158 Mbytes
            Plugins Installed=AK Weather 4.0.0.99,HSBuddy 3.25.614.1,Z-Wave 3.0.4.0,Z-Wave UI 1.0.0.0
            Disk Size=29.72GB
              Here is a picture from a second location that I added, new lat/long from the first location, but same results.
                Can you check Data\AKWeather folder for swob-xml_station_list_XXXX.json files?
                  running command ls Data/AKWeather
                  KNMI_stations.json
                  bom_stations_1.json
                  bom_stations_2.csv
                  bom_stations_2.json
                  swob-xml_station_list.json
                    Just tried changing the lat/long on my second station, and it gave me the attached error. if I hit "OK" and try to save again, it does seem to save. There was no corresponding log entry though for when I saved it.
                      I deleted the plug-in, then deleted the Data/AKWeather folder as well. Then I reinstalled the plugin to start from scratch, here are my logs from reinstallation to setting up a location and changing the station it is using to CWPO-AUTO. Below I also included the log from the install.
                      8/29/2021 1:32:20 PM
                      AK Weather Info [317] Farm: (CanWeather) 'avg_snw_dpth_pst5mts_3' -1 cm
                      AK Weather Info [317] Farm: (CanWeather) 'avg_snw_dpth_pst5mts_2' -1 cm
                      AK Weather Info [317] Farm: (CanWeather) 'avg_snw_dpth_pst5mts_1' 0 cm
                      AK Weather Info [317] Farm: (CanWeather) 'wetblb_temp' 15.0 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'mslp' 1016.2 hPa
                      AK Weather Info [317] Farm: (CanWeather) 'dwpt_temp' 13.5 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'max_air_temp_pst24hrs' 25.2 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'min_air_temp_pst24hrs' 9.5 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'pres_tend_amt_pst3hrs' 0.9 hPa
                      AK Weather Info [317] Farm: (CanWeather) 'pres_tend_char_pst3hrs' 2 code
                      AK Weather Info [317] Farm: (CanWeather) 'pcpn_amt_pst6hrs' 0.0 mm
                      AK Weather Info [317] Farm: (CanWeather) 'pcpn_amt_pst3hrs' 0.0 mm
                      AK Weather Info [317] Farm: (CanWeather) 'max_air_temp_pst6hrs' 18.7 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'pcpn_amt_pst24hrs' 0.0 mm
                      AK Weather Info [317] Farm: (CanWeather) 'pcpn_snc_last_syno_hr' 0.0 mm
                      AK Weather Info [317] Farm: (CanWeather) 'min_air_temp_pst6hrs' 11.5 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'rnfl_amt_pst1hr' 0.0 mm
                      AK Weather Info [317] Farm: (CanWeather) 'avg_snw_dpth_pst5mts' 0 cm
                      AK Weather Info [317] Farm: (CanWeather) 'pcpn_amt_pst1hr' 0.0 mm
                      AK Weather Info [317] Farm: (CanWeather) 'avg_***_pcpn_gag_wt_fltrd_pst5mts' 74.7 kg/m??
                      AK Weather Info [317] Farm: (CanWeather) 'stn_pres' 959.8 hPa
                      AK Weather Info [317] Farm: (CanWeather) 'avg_wnd_spd_pcpn_gag_pst10mts' 10.1 km/h
                      AK Weather Info [317] Farm: (CanWeather) 'avg_wnd_dir_10m_pst2mts' 292 ??
                      AK Weather Info [317] Farm: (CanWeather) 'avg_wnd_spd_10m_pst2mts' 9.6 km/h
                      AK Weather Info [317] Farm: (CanWeather) 'wnd_dir_10m_pst10mts_max_spd' 274 ??
                      AK Weather Info [317] Farm: (CanWeather) 'max_wnd_spd_10m_pst10mts' 21.8 km/h
                      AK Weather Info [317] Farm: (CanWeather) 'wnd_dir_10m_pst1hr_max_spd' 275 ??
                      AK Weather Info [317] Farm: (CanWeather) 'max_wnd_spd_pst1hr_tm' 1709 hhmm
                      AK Weather Info [317] Farm: (CanWeather) 'max_wnd_spd_10m_pst1hr' 27.9 km/h
                      AK Weather Info [317] Farm: (CanWeather) 'avg_wnd_dir_10m_pst1hr' 277 ??
                      AK Weather Info [317] Farm: (CanWeather) 'avg_wnd_spd_10m_pst1hr' 16.8 km/h
                      AK Weather Info [317] Farm: (CanWeather) 'avg_wnd_dir_10m_pst10mts' 279 ??
                      AK Weather Info [317] Farm: (CanWeather) 'avg_wnd_spd_10m_pst10mts' 13.3 km/h
                      AK Weather Info [317] Farm: (CanWeather) 'min_rel_hum_pst1hr' 69 %
                      AK Weather Info [317] Farm: (CanWeather) 'min_air_temp_pst1hr' 16.4 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'max_rel_hum_pst1hr' 78 %
                      AK Weather Info [317] Farm: (CanWeather) 'max_air_temp_pst1hr' 18.7 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'avg_air_temp_pst1hr' 17.3 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'rel_hum' 77 %
                      AK Weather Info [317] Farm: (CanWeather) 'air_temp' 17.6 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'logr_panl_temp' 21.9 ??C
                      AK Weather Info [317] Farm: (CanWeather) 'min_batry_volt_pst1hr' 13.17 V
                      AK Weather Info [317] Farm: (CanWeather) 'max_batry_volt_pst1hr' 13.31 V
                      AK Weather Info [317] Farm: (CanWeather) 'data_avail' 100 %
                      8/29/2021 1:32:18 PM
                      AK Weather Info [317] Farm: Getting file 'CWPO-AUTO-swob.xml'
                      8/29/2021 1:32:15 PM
                      AK Weather Warning [317] Farm: Selected 'CWPO-AUTO' - CWPO PILOT MOUND (AUT), Manitoba 'MB' ( km) Forecast Station 's0000289' (1 km)
                      8/29/2021 1:32:02 PM
                      AK Weather Warning [397] Humidity [2]: CheckStatusGraphicExists[(-2147482648-2147482647)$%0$ /images/HomeSeer/status/water.gif] : [(-2147482648-2147482647)$%0$ /images/HomeSeer/status/water.gif]
                      8/29/2021 1:32:01 PM
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(60-99.9999)$%0$ /images/HomeSeer/status/Thermometer-110.png] : [(60-99.9999)$%0$ /images/HomeSeer/status/Thermometer-110.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(50-59.9999)$%0$ /images/HomeSeer/status/Thermometer-100.png] : [(50-59.9999)$%0$ /images/HomeSeer/status/Thermometer-100.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(40-49.9999)$%0$ /images/HomeSeer/status/Thermometer-90.png] : [(40-49.9999)$%0$ /images/HomeSeer/status/Thermometer-90.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(30-39.9999)$%0$ /images/HomeSeer/status/Thermometer-80.png] : [(30-39.9999)$%0$ /images/HomeSeer/status/Thermometer-80.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(20-29.9999)$%0$ /images/HomeSeer/status/Thermometer-70.png] : [(20-29.9999)$%0$ /images/HomeSeer/status/Thermometer-70.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(10-19.9999)$%0$ /images/HomeSeer/status/Thermometer-60.png] : [(10-19.9999)$%0$ /images/HomeSeer/status/Thermometer-60.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(0-9.9999)$%0$ /images/HomeSeer/status/Thermometer-50.png] : [(0-9.9999)$%0$ /images/HomeSeer/status/Thermometer-50.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(-10--0.0001)$%0$ /images/HomeSeer/status/Thermometer-40.png] : [(-10--0.0001)$%0$ /images/HomeSeer/status/Thermometer-40.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(-20--10.0001)$%0$ /images/HomeSeer/status/Thermometer-30.png] : [(-20--10.0001)$%0$ /images/HomeSeer/status/Thermometer-30.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(-30--20.0001)$%0$ /images/HomeSeer/status/Thermometer-20.png] : [(-30--20.0001)$%0$ /images/HomeSeer/status/Thermometer-20.png]
                      AK Weather Warning [394] Temperat Min [2]: CheckStatusGraphicExists[(-40--30.0001)$%0$ /images/HomeSeer/status/Thermometer-10.png] : [(-40--30.0001)$%0$ /images/HomeSeer/status/Thermometer-10.png]
                      8/29/2021 1:31:47 PM
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(60-99.9999)$%0$ /images/HomeSeer/status/Thermometer-110.png] : [(60-99.9999)$%0$ /images/HomeSeer/status/Thermometer-110.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(50-59.9999)$%0$ /images/HomeSeer/status/Thermometer-100.png] : [(50-59.9999)$%0$ /images/HomeSeer/status/Thermometer-100.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(40-49.9999)$%0$ /images/HomeSeer/status/Thermometer-90.png] : [(40-49.9999)$%0$ /images/HomeSeer/status/Thermometer-90.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(30-39.9999)$%0$ /images/HomeSeer/status/Thermometer-80.png] : [(30-39.9999)$%0$ /images/HomeSeer/status/Thermometer-80.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(20-29.9999)$%0$ /images/HomeSeer/status/Thermometer-70.png] : [(20-29.9999)$%0$ /images/HomeSeer/status/Thermometer-70.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(10-19.9999)$%0$ /images/HomeSeer/status/Thermometer-60.png] : [(10-19.9999)$%0$ /images/HomeSeer/status/Thermometer-60.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(0-9.9999)$%0$ /images/HomeSeer/status/Thermometer-50.png] : [(0-9.9999)$%0$ /images/HomeSeer/status/Thermometer-50.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(-10--0.0001)$%0$ /images/HomeSeer/status/Thermometer-40.png] : [(-10--0.0001)$%0$ /images/HomeSeer/status/Thermometer-40.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(-20--10.0001)$%0$ /images/HomeSeer/status/Thermometer-30.png] : [(-20--10.0001)$%0$ /images/HomeSeer/status/Thermometer-30.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(-30--20.0001)$%0$ /images/HomeSeer/status/Thermometer-20.png] : [(-30--20.0001)$%0$ /images/HomeSeer/status/Thermometer-20.png]
                      AK Weather Warning [334] Temperat Min: CheckStatusGraphicExists[(-40--30.0001)$%0$ /images/HomeSeer/status/Thermometer-10.png] : [(-40--30.0001)$%0$ /images/HomeSeer/status/Thermometer-10.png]
                      8/29/2021 1:31:46 PM
                      AK Weather Error HS3 APIVersion: System.Exception: Client is not connected to the server. at HSCF.Communication.Scs.Client.ScsClientBase.SendMessage (HSCF.Communication.Scs.Communication.Messages.IScsMessage message) [0x0000f] in :0 at HSCF.Communication.ScsServices.Communication.RequestReplyMes senger`1[T].SendMessageAndWaitForResponse (HSCF.Communication.Scs.Communication.Messages.IScsMessage message, System.Int32 timeoutMilliseconds) [0x00044] in :0 at HSCF.Communication.ScsServices.Communication.RequestReplyMes senger`1[T].SendMessageAndWaitForResponse (HSCF.Communication.Scs.Communication.Messages.IScsMessage message) [0x00008] in :0 at HSCF.Communication.ScsServices.Communication.RemoteInvokePro xy`2[TProxy,TMessenger].Invoke (System.Runtime.Remoting.Messaging.IMessage msg) [0x00056] in :0 at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, System.Runtime.Remoting.Messaging.IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x000d6] in :0 at (wrapper managed-to-native) System.Object.__icall_wrapper_mono_remoting_wrapper(intptr,i ntptr) at (wrapper remoting-invoke) HomeSeerAPI.IHSApplication.get_APIVersion() at PluginLib.PluginBase.get_HS3 () [0x00019] in :0
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(60-99.9999)$%0$ /images/HomeSeer/status/Thermometer-110.png] : [(60-99.9999)$%0$ /images/HomeSeer/status/Thermometer-110.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(50-59.9999)$%0$ /images/HomeSeer/status/Thermometer-100.png] : [(50-59.9999)$%0$ /images/HomeSeer/status/Thermometer-100.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(40-49.9999)$%0$ /images/HomeSeer/status/Thermometer-90.png] : [(40-49.9999)$%0$ /images/HomeSeer/status/Thermometer-90.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(30-39.9999)$%0$ /images/HomeSeer/status/Thermometer-80.png] : [(30-39.9999)$%0$ /images/HomeSeer/status/Thermometer-80.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(20-29.9999)$%0$ /images/HomeSeer/status/Thermometer-70.png] : [(20-29.9999)$%0$ /images/HomeSeer/status/Thermometer-70.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(10-19.9999)$%0$ /images/HomeSeer/status/Thermometer-60.png] : [(10-19.9999)$%0$ /images/HomeSeer/status/Thermometer-60.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(0-9.9999)$%0$ /images/HomeSeer/status/Thermometer-50.png] : [(0-9.9999)$%0$ /images/HomeSeer/status/Thermometer-50.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(-10--0.0001)$%0$ /images/HomeSeer/status/Thermometer-40.png] : [(-10--0.0001)$%0$ /images/HomeSeer/status/Thermometer-40.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(-20--10.0001)$%0$ /images/HomeSeer/status/Thermometer-30.png] : [(-20--10.0001)$%0$ /images/HomeSeer/status/Thermometer-30.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(-30--20.0001)$%0$ /images/HomeSeer/status/Thermometer-20.png] : [(-30--20.0001)$%0$ /images/HomeSeer/status/Thermometer-20.png]
                      AK Weather Warning [330] Temperature: CheckStatusGraphicExists[(-40--30.0001)$%0$ /images/HomeSeer/status/Thermometer-10.png] : [(-40--30.0001)$%0$ /images/HomeSeer/status/Thermometer-10.png]
                      8/29/2021 1:31:43 PM
                      AK Weather Warning [317] Farm: findd(stn_pres) 'MSNG': Input string was not in a correct format.
                      8/29/2021 1:31:39 PM
                      AK Weather Warning [317] Farm: Selected 'CNES-AUTO' - CNES EDMONTON SOUTH CAMPUS, Alberta 'AB' ( km) Forecast Station 's0000045' (5 km)
                      8/29/2021 1:30:50 PM
                      AK Weather Warning [317] Farm: Provider not selected
                      8/29/2021 1:30:44 PM
                      AK Weather Info 8/29/2021 1:30:44 PM AK Weather ver. 4.0.0.99 (4.0.1.52)
                      8/29/2021 1:30:45 PM
                      HomeSeer Plug-In Finished initializing plug-in AK Weather
                      HomeSeer Starting Plug-In AK Weather loaded in 2102 milliseconds
                      HomeSeer Starting Plug-In Plugin AK Weather started successfully in 965 milliseconds
                      HomeSeer Starting Plug-In Initializing plugin AK Weather ...
                      8/29/2021 1:30:43 PM
                      HomeSeer Info Plugin AKWeather with instance AK Weather has connected. IP:127.0.0.1:52362
                      8/29/2021 1:30:42 PM
                      HomeSeer Plug-In Interface AK Weather is running as a trial, 30 days remaining.
                      8/29/2021 1:30:36 PM
                      HomeSeer Updater Info Plugin AK Weather installed successfully.
                      8/29/2021 1:30:30 PM
                      HomeSeer Updater Info Extraction Complete.
                      HomeSeer Updater Info Extracting files from zip file: Weatherbit.zip
                      HomeSeer Updater Info Extracting files from zip file: Openweathermap.zip
                      HomeSeer Updater Info Extracting files from zip file: DarkSky.zip
                      HomeSeer Updater Info Extracting files from zip file: WeatherUnderground.zip
                      8/29/2021 1:30:29 PM
                      HomeSeer Updater Info Extracting files from zip file: YR.zip
                      HomeSeer Updater Info Extracting files from zip file: AQI.zip
                      HomeSeer Updater Info Extracting files from zip file: BOM.zip
                      HomeSeer Updater Info Extracting files from zip file: Metoffice.zip
                      HomeSeer Updater Info Extracting files from zip file: CanWeather.zip
                      HomeSeer Updater Info Extracting files from zip file: AerisWeather.zip
                      8/29/2021 1:30:28 PM
                      HomeSeer Updater Info Extracting files from zip file: Accuweather.zip
                      HomeSeer Updater Info Extracting files from zip file: weather_icons.zip
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/Data/AKWeather/swob-xml_station_list.json
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/Data/AKWeather/bom_stations_2.csv
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/Data/AKWeather/bom_stations_2.json
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/Data/AKWeather/bom_stations_1.json
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/Data/AKWeather/KNMI_stations.json
                      HomeSeer Updater Info Making dir: /usr/local/HomeSeer/Data/AKWeather/
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/zlib1.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/netcdf.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/hdf5_hl.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/hdf5.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/ScientificDataSet.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/DynamicInterop.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/KMDS.exe
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/Microsoft.Bcl.HashCode.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/Microsoft.Bcl.AsyncInterfaces.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/CsvHelper.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/CoordinateSharp.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/Newtonsoft.Json.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/html/abk.css
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/bin/AKWeather/PluginLib.dll
                      HomeSeer Updater Info Copying file: /usr/local/HomeSeer/HSPI_AKWeather.exe.config
                      8/29/2021 1:30:23 PM
                      HomeSeer Updater Info Plugin install for AK Weather starting...
                        Ok, this shows importance of providing information for troubleshooting. You are on Linux and Mono doesn't include System.Device.dll - the exception you are getting.
                        I added the System.Device.dll to the installer (ver 4.0.0.101 BETA) - please try, but it may not work, may need more dlls - .NET dependencies on Linux is always a problem
                          I added the System.Device.dll to the installer (ver 4.0.0.100 BETA) - please try, but it may not work, .NET dependencies on Linux is always a problem
                          Yes, I apologize for not giving enough info at first, I should have known better! But thank you for the quick fix I'll try it out and get back to you.
                            Went to download the Beta plugin, and got this message.
                              Could be updater issue, just try again
