Can_Weather - It seems hit or miss with the ° symbol
    Originally posted by cd36 View Post
    It seems hit or miss with the ° symbol. For instance:
    12°C - 23 ??C, Sunny. Becoming a mix of sun and cloud this afternoon. High 23. UV index 6 or high.
    23$%0$ Mostly Cloudy (33 m ago)
    Both of those are taken from a device created by the plugin. Sometimes it properly shows the ° symbol, but more often then not it does not.
    I'll check, but you can enable Log for the location and post your logs here.
    I seem to be having issues with my logs, for some reason they are 10 hours and 15 minutes behind real-time. Here is a sample of a log pulled from last night at 11:45:
    8/28/2021 11:45:33 PM
    AK Weather Info [181] Farm: (CanWeather) 'avg_snw_dpth_pst5mts_3' -1 cm
    AK Weather Info [181] Farm: (CanWeather) 'avg_snw_dpth_pst5mts_2' -1 cm
    AK Weather Info [181] Farm: (CanWeather) 'avg_snw_dpth_pst5mts_1' -1 cm
    AK Weather Info [181] Farm: (CanWeather) 'wetblb_temp' 13.1 ??C
    AK Weather Info [181] Farm: (CanWeather) 'dwpt_temp' 12.1 ??C
    AK Weather Info [181] Farm: (CanWeather) 'mslp' 1011.7 hPa
    AK Weather Info [181] Farm: (CanWeather) 'min_air_temp_pst24hrs' 14.6 ??C
    AK Weather Info [181] Farm: (CanWeather) 'pres_tend_amt_pst3hrs' 0.1 hPa
    AK Weather Info [181] Farm: (CanWeather) 'max_air_temp_pst24hrs' 23.6 ??C
    AK Weather Info [181] Farm: (CanWeather) 'pres_tend_char_pst3hrs' 3 code
    AK Weather Info [181] Farm: (CanWeather) 'pcpn_amt_pst6hrs' 0.0 mm
    AK Weather Info [181] Farm: (CanWeather) 'pcpn_snc_last_syno_hr' 0.0 mm
    AK Weather Info [181] Farm: (CanWeather) 'pcpn_amt_pst3hrs' 0.0 mm
    AK Weather Info [181] Farm: (CanWeather) 'min_air_temp_pst6hrs' 14.7 ??C
    AK Weather Info [181] Farm: (CanWeather) 'max_air_temp_pst6hrs' 23.5 ??C
    AK Weather Info [181] Farm: (CanWeather) 'pcpn_amt_pst24hrs' 0.0 mm
    AK Weather Info [181] Farm: (CanWeather) 'rnfl_amt_pst1hr' 0.0 mm
    AK Weather Info [181] Farm: (CanWeather) 'avg_snw_dpth_pst5mts' -1 cm
    AK Weather Info [181] Farm: (CanWeather) 'pcpn_amt_pst1hr' 0.0 mm
    AK Weather Info [181] Farm: (CanWeather) 'avg_***_pcpn_gag_wt_fltrd_pst5mts' 87.8 kg/m??
    AK Weather Info [181] Farm: (CanWeather) 'stn_pres' 967.0 hPa
    AK Weather Info [181] Farm: (CanWeather) 'avg_wnd_spd_pcpn_gag_pst10mts' 3.0 km/h
    AK Weather Info [181] Farm: (CanWeather) 'avg_wnd_dir_10m_pst2mts' 180 ??
    AK Weather Info [181] Farm: (CanWeather) 'avg_wnd_spd_10m_pst2mts' 7.2 km/h
    AK Weather Info [181] Farm: (CanWeather) 'wnd_dir_10m_pst10mts_max_spd' 162 ??
    AK Weather Info [181] Farm: (CanWeather) 'max_wnd_spd_10m_pst10mts' 8.0 km/h
    AK Weather Info [181] Farm: (CanWeather) 'wnd_dir_10m_pst1hr_max_spd' 298 ??
    AK Weather Info [181] Farm: (CanWeather) 'max_wnd_spd_pst1hr_tm' 0306 hhmm
    AK Weather Info [181] Farm: (CanWeather) 'max_wnd_spd_10m_pst1hr' 16.1 km/h
    AK Weather Info [181] Farm: (CanWeather) 'avg_wnd_dir_10m_pst1hr' 276 ??
    AK Weather Info [181] Farm: (CanWeather) 'avg_wnd_spd_10m_pst1hr' 8.2 km/h
    AK Weather Info [181] Farm: (CanWeather) 'avg_wnd_dir_10m_pst10mts' 173 ??
    AK Weather Info [181] Farm: (CanWeather) 'avg_wnd_spd_10m_pst10mts' 5.8 km/h
    AK Weather Info [181] Farm: (CanWeather) 'min_rel_hum_pst1hr' 78 %
    AK Weather Info [181] Farm: (CanWeather) 'min_air_temp_pst1hr' 14.7 ??C
    AK Weather Info [181] Farm: (CanWeather) 'max_rel_hum_pst1hr' 85 %
    AK Weather Info [181] Farm: (CanWeather) 'max_air_temp_pst1hr' 17.5 ??C
    AK Weather Info [181] Farm: (CanWeather) 'avg_air_temp_pst1hr' 16.8 ??C
    AK Weather Info [181] Farm: (CanWeather) 'rel_hum' 85 %
    AK Weather Info [181] Farm: (CanWeather) 'air_temp' 14.7 ??C
    AK Weather Info [181] Farm: (CanWeather) 'logr_panl_temp' 21.6 ??C
    8/28/2021 11:45:32 PM
    AK Weather Info [181] Farm: (CanWeather) 'min_batry_volt_pst1hr' 12.42 V
    AK Weather Info [181] Farm: (CanWeather) 'max_batry_volt_pst1hr' 12.52 V
    AK Weather Info [181] Farm: (CanWeather) 'data_avail' 100 %
    8/28/2021 11:45:31 PM
    AK Weather Info [181] Farm: Getting file 'CPOY-AUTO-swob.xml'
      Thank you for providing the logs. The "??" string come from the provider, I can remove it in the next version.
        Is the %0$ coming from the suffix setting on the homeseer device? Is there any harm in deleting that suffix besides how long it takes to do it to all of them?
          Yes, that's from HS, but all it means - that it's expecting the units string to be provided by the plugin. So for now just wait for other fixes.
