Meteobridge
This is a sticky topic.
    Meteobridge
    Originally posted by vince954 View Post
    Alex, sorry for the delay, did not get notification, i have been using this script to import select data items from the meteobridge device, this script runs every few minutes and works fine.
    Imports System.Collections.Generic
    Dim USERNAME as string= "meteobridge"
    Dim PASSWORD as string= "meteobridge"
    Dim URL As String = "192.168.1.48/cgi-bin/livedataxml.cgi"
    URL = USERNAME & ":" & PASSWORD & "@" & URL
    Dim Query As String = hs.GETURL(URL,"",False,80)
    Dim xmlData As New XmlDocument()
    Dim xmlnodelist As XmlNodeList
    Dim xmlnode As XmlNode
    Dim MeteoData As New Dictionary(Of String, Items)
    xmlData.LoadXml(Query)
    ' Update the Ref #s for the devices you have. The name isn't used and can stay the same
    xmlnode = xmlData.SelectSingleNode("logger/TH")
    MeteoData.Add("OutsideTemperature", New Items With {.Ref=1976, .Value=CtoF(xmlnode.Attributes.GetNamedItem("temp").Value)})
    MeteoData.Add("OutsideHumidity", New Items With {.Ref=100, .Value=xmlnode.Attributes.GetNamedItem("hum").Value})
    MeteoData.Add("OutsideDewpoint", New Items With {.Ref=104, .Value=CtoF(xmlnode.Attributes.GetNamedItem("dew").Value)})
    xmlnode = xmlData.SelectSingleNode("logger/THB")
    MeteoData.Add("InsideTemperature", New Items With {.Ref=1975, .Value=CtoF(xmlnode.Attributes.GetNamedItem("temp").Value)})
    MeteoData.Add("InsideHumidity", New Items With {.Ref=839, .Value=xmlnode.Attributes.GetNamedItem("hum").Value})
    MeteoData.Add("InsideDewpoint", New Items With {.Ref=104, .Value=CtoF(xmlnode.Attributes.GetNamedItem("dew").Value)})
    MeteoData.Add("BarPress", New Items With {.Ref=105, .Value=MBtoHG(xmlnode.Attributes.GetNamedItem("press").Value )})
    MeteoData.Add("SeaPress", New Items With {.Ref=0, .Value=MBtoHG(xmlnode.Attributes.GetNamedItem("seapress").Va lue)})
    xmlnode = xmlData.SelectSingleNode("logger/WIND")
    MeteoData.Add("WindSpeed", New Items With {.Ref = 102, .Value = MStoMPH(xmlnode.Attributes.GetNamedItem("wind").Value)})
    MeteoData.Add("WindGust", New Items With {.Ref = 106, .Value = MStoMPH(xmlnode.Attributes.GetNamedItem("gust").Value)})
    MeteoData.Add("WindChill", New Items With {.Ref = 2253, .Value = CtoF(xmlnode.Attributes.GetNamedItem("chill").Value)})
    MeteoData.Add("WindDir", New Items With {.Ref = 137, .Value = xmlnode.Attributes.GetNamedItem("dir").Value})
    xmlnode = xmlData.SelectSingleNode("logger/RAIN")
    MeteoData.Add("RainRate", New Items With {.Ref=0, .Value=MMtoIN(xmlnode.Attributes.GetNamedItem("rate").Value) })
    MeteoData.Add("RainTotal", New Items With {.Ref = 798, .Value = MMtoIN(xmlnode.Attributes.GetNamedItem("total").Value)})
    MeteoData.Add("RainDelta", New Items With {.Ref = 107, .Value = MMtoIN(xmlnode.Attributes.GetNamedItem("delta").Value)})
    ' Update HS3 virtual devices
    updateHS3(MeteoData)
    End Sub
    Sub updateHS3(ByVal data As Object)
    Dim val As Double
    For Each item As KeyValuePair(Of String, Items) In data
    if item.Value.Ref > 0
    val = Convert.ToDouble(item.Value.Value)
    'hs.WriteLog("MeteoPoll","Key=" & item.Key & ", Ref=" & item.Value.Ref & ", Value=" & val)
    hs.SetDeviceValueByRef(item.Value.Ref,val, true)
    End If
    Next
    End Sub
    Function CtoF (ByVal C As Decimal) As Decimal
    Return Format(((9*C)/5 ) + 32,"0.00")
    End Function
    Function MBtoHG(ByVal MB As Decimal) As Decimal
    Return Format(MB*0.02953,"0.00")
    End Function
    Function MMtoIN(ByVal MM As Decimal) As Decimal
    Return Format(MM/25.4,"0.00")
    End Function
    Function MStoMPH(ByVal MS As Decimal) As Decimal
    Return Format(MS/0.44704,"0.00")
    End Function
    Public Class Items
    Public Property Ref As Integer
    Public Property Value As Double
    Public Sub New()
    End Sub
    End Class
    Ver 4.0.1.3 - Added Metobridge support - both Local (WiFi) and Remote (Internet) connections
    Current version implements basic readings. Many other variables may be implemented, see https://meteobridge.com/wiki/index.php/Templates
    Let me know of any requirements.
      Configuration
      Meteobridge provider supports both Local (WiFi) and Remote (Internet) connections.
      For Remote connection you need to enter the station ID (32 character string, see below).
      For Local connection enter bridge IP Address.
      Click image for larger version  Name:	MeteobridgeConfig.png Views:	30 Size:	64.9 KB ID:	1492944
        vince954 ?
          Tinkering here installed AKWeather and connecting it to the Meteobridge. I put the IP in and it does not connect.
          It will not save settings.
          - Pete
          Auto mator
          Fanless Intel® Celeron N3160 SoC 8Gb
            BTW have owned the Meteostick for some 5-6 years with the intention of using it with WeatherWX. Never did this.
            It was easy to install the Meteobridge firmware on my old non used TP-travel router.
            - Pete
            Auto mator
              Pete I tested Meteobridge remote via their server by specifying the station ID, not local IP Address, since I don't have the device.
              Can you please provide more info? I.e. Logs, screenshots?
                Originally posted by brientim View Post
                The Meteobridge work great and there is no visible issues to date.
                Tim, did you test Local IP Address, or Remote using station ID?
                  Local.
                    Working here now with Firefox. I was getting the not saving error with Chrome.
                    Configured the Meteobridge with Wireless. I am liking this better than having to plug in the Meteostick to a computer.
                    Currently also using the Jon00's Cumulus plugin. Way back Adam configured the Cumulus plugin to work with two locations (weather stations).
                    CumulusMX now speaks MQTT. Wishing the Meteobridge did. The WiFi logger speaks MQTT but you have to plug that in to a console.
                    - Pete
                    Auto mator
                      So Pete , I don't need to spend time om Meteostick in your view? I think that Meteobridge and WLL should be more valuable?
                        Yes.
                        - Pete
                        Auto mator
                          Yes.
                          "Yes" means "I don't need to spend time om Meteostick"?
                            I don't need to spend time on Meteostick in your view?
                            Yes you do not need to spend any more time on the Meteostick.
                            Yes.
                            - Pete
                            Auto mator
                              Great Pete
