Meteobridge
This is a sticky topic.
    #16
    So today looking a HS4 display of AKWeather - Meteobridge variables. Personally all of the variables displays in HS4 stinks. That said installed Jon00 links program to see the variables in the old HS3 format.
    So looking and comparing: ( I have CumulusMX - serial logger running on same computer, mcsMQTT running on Homeseer, HA running on same computer)
    1 - AKWeather - Meteobridge variables
    2 - Jon00 CumuluxMX Realtime.txt variables
    3 - MQTT from CumulusMX variables to Homeseer and Home Assistant
    4 - Home Assistant Meteobridge plugin variables. (Meteobridge datalogger)
    5 - WeatherXML running today on Homeseer 3 Pro. (have it installed on HS4 Pro but not configured).*
    6 - WLL - will purchase next week for configuration of house #2 that is currently configured with HS4 and HA.
    * Base plugin I am using to compare AKWeather plugin.
    A few years ago tested Linux WeatherWX running on Homeseer computer and it worked well. This past week tested WeatherDisplay on Linux. Very slow running. Not impressed at all with it. Maybe it works better on Windows.
    With the above written wanting to use weather station variables in HS4 and continue to run autonomous weather software.
    Historically have used Cumulus guages in HS2 and HS3 HSTouch tabletop screens (running in Windows embedded).
    I am not tethered to my cell phones but lately using Android. I do have multiple cellular accounts and still have Windows 10 mobile phone and an Apple ios phone (both off at this time). I keep all cell phones off when at home. That said I have one LTE modem pass voice line to house with two VOIP lines at this time.
    Click image for larger version  Name:	guages.jpg Views:	0 Size:	61.6 KB ID:	1496953
    - Pete
    Auto mator
    Fanless IntelĀ® Celeron N3160 SoC 8Gb
      #17
      Pete remember - if you need anything - I can implement
      [EDIT]
      Also, I don't usually test imperial units, beware
