Creating a location without specifying a provider triggers a reflection error
    It seems if you try to create a new location but don't select a provider, it doesn't handle the missing data gracefully. Instead of prompting you to enter a provider I get a reflection error. It appears in a dialog box that I can't copy and paste otherwise I'd paste the error here. I believe this is repeatable though. Let me know if you still need the error and I can try to take some screen grabs.
    Sure I need the screenshots and more info about error. What's "reflection error"? Info about OS, HS, plugin version?
      Okay. To reproduce the error, create a new location, enter an API key (can be real or a made up value) and then skip selecting a provider. The reflection error then will appear. See attached.
      Click image for larger version  Name:	image_104854.png Views:	6 Size:	86.4 KB ID:	1494824
      Click image for larger version  Name:	image_104856.png Views:	6 Size:	90.0 KB ID:	1494825
      Click image for larger version  Name:	image_104855.png Views:	6 Size:	87.9 KB ID:	1494826
        begunfx why do you enter the API key without provider selected? The key is saved per provider, so it doesn't make sense anyways.
          Try ver 4.0.1.8 (in BETA)
            This was a user input error on my part by not selecting the provider, but the plugin should handle this gracefully and remind the user that they forgot to select a provider.
              Will do. Thanks
                I just installed 4.0.1.8 and still see the ability to add the API key even though no provider was selected.
                  So what? Did you try to enter the API key?
                  I can hide the API key input until you select the provider and save settings, then you need second step - enter the key and save settings again?
                    3. Select the provider from the list
                    4. If required by provider, enter the API key. The provider specific request "Link for API key" is shown below.
                    That's the instructions. User "should" follow the instructions, then plugin "should" work
                      Okay. Sorry, I guess I assumed that you could reveal the API key once you selected a provider. Didn't realize that having to save 2x was required to reveal the API key. I guess just having the instructions is the only option. I just tested it without selecting a provider and adding an API and it doesn't give the reflection error anymore. It would be nice if it prompted the user that they didn't select a provider, but if there are limitations with HS4, then don't worry about it. Thanks for fixing the reflection error.
                        In HS4 settings screens are static, so it's not possible to dynamically show/hide elements.
