Plugin won't start - Critical error on Init
    Loaded a new Linux box with HS4, plugin won't start. Uninstalled and reinstalled a couple of times, including deleting everything AKWeather* on the box (files and folders) and reinstalling. I can't even get to setup anything in the plugin.
    O/S = Linux lenovo-HS4.9.0-16-amd64 #1 SMP Debian 4.9.272-2 (2021-07-19) x86_64 GNU/Linux
    Logfile:
    9/21/2021 12:02:01 PM HomeSeer Plug-In Finished initializing plug-in AK Weather
    9/21/2021 12:02:01 PM HomeSeer Starting Plug-In AK Weather loaded in 300 milliseconds
    9/21/2021 12:02:01 PM HomeSeer Info Plugin AK Weather with ID: AKWeather and Instance: has disconnected
    9/21/2021 12:02:01 PM HomeSeer Error Initializing plug-in(1): AK Weather Instance::Error on InitIO: Could not resolve type with token 010000b2 Time to load: 12 milliseconds
    9/21/2021 12:02:01 PM AK Weather Error Exception in Initialize: System.TypeLoadException: Could not resolve type with token 010000b2
    at PluginLib.PluginBase.Initialize () [0x00037] in :0
    9/21/2021 12:02:01 PM HomeSeer Starting Plug-In Initializing plugin AK Weather ...
    9/21/2021 12:02:01 PM HomeSeer Info Plugin AKWeather with instance AK Weather has connected. IP:127.0.0.1:40660
    Click image for larger version  Name:	akweather.JPG Views:	0 Size:	54.0 KB ID:	1497754 Click image for larger version  Name:	akweather2.JPG Views:	0 Size:	48.6 KB ID:	1497755
    I might have found the problem in the v4.0.1.15 version of the plugin. It's installing the image files in a path below HomeSeer and duplicating usr/local/HomeSeer
    /usr/local/HomeSeer/usr/local/HomeSeer/html/images/AKWeather
      More info from the logfile:
      9/21/2021 4:52:46 PM HomeSeer Error Initializing plug-in(1): AK Weather Instance::Error on InitIO: Could not resolve type with token 010000b2 Time to load: 10 milliseconds
      9/21/2021 4:52:46 PM AK Weather Error
      Exception in Initialize: System.TypeLoadException: Could not resolve type with token 010000b2 at PluginLib.PluginBase.Initialize () [0x00037] in :0
        First of all, when reporting a problem please provide output from Tools=>Help
        Also, latest BETA is 4.0.1.24
          That's not the plugin problem - it's the HS installer problem, I don't have control over it
            Resolved - Not an installer or plugin problem. I figured out that I needed to install Mono 6.
              That's why I said "First of all, when reporting a problem please provide output from Tools=>Help" - it gives Mono version
                Originally posted by alexbk66 View Post
                  Glad you sorted this out
