uRADMonitor Air Quality Sensors
This is a sticky topic.
    #16
    Hello Alex,
    Thank you for you work and the update.
    All working well, and the update in post#2 was straight forward.
    Please see suggested changes below.
    Pressure is correct when pulled by remote API but needs to be decided by 100
    All other apply to local and remote API
    Feature Comments SI Icon
    Pressure divide by 100 (local) rounded hPa
    Air Quality Ch2o Formaldehyde CH2o - icon update ppm new CH2o icon attached
    Air Quality Voc Renamed Air Quality VOC - icon update ppm organic_compound.png
    BATTERY In the case is the voltage of A3 geiger counter V could be ignored
      #17
      Thanks Tim. You attached only one icon?
      Also icon for pressure could be improved?
        #18
        Some of them were the standard HS Status icons located \html\images\HomeSeer\status\
        Otherwise see attached.
        Pressure use \html\images\HomeSeer\status\pressure.png if not in the attached.
        Add an Info one as well
          #19
          Ver 4.0.1.49 - Made the above changes, need to delete HS devices (except for Location root)
            #20
            Hello Alex,
            Thank you and working as it should.
            Air Quality CPM Renamed Radiation - icon update
            I have done this manually and renamed the Feature to Radiation.
            I have also included a few better icons for loudness, pressure (Barometer or hPA), radiation, thermometer, VOC, Co2, and Pm2.5
            Click image for larger version  Name:	image_106236.png Views:	9 Size:	8.8 KB ID:	1503693 Click image for larger version  Name:	image_106239.png Views:	7 Size:	19.5 KB ID:	1503694 Click image for larger version  Name:	image_106240.png Views:	7 Size:	149.1 KB ID:	1503695 Click image for larger version  Name:	image_106241.png Views:	7 Size:	86.1 KB ID:	1503696 Click image for larger version  Name:	image_106242.png Views:	7 Size:	164.7 KB ID:	1503697 Click image for larger version  Name:	image_106243.png Views:	7 Size:	28.9 KB ID:	1503698 Click image for larger version  Name:	image_106244.jpg Views:	7 Size:	12.2 KB ID:	1503699 Click image for larger version  Name:	image_106245.png Views:	7 Size:	65.6 KB ID:	1503700 Click image for larger version  Name:	image_106246.png Views:	6 Size:	39.1 KB ID:	1503701
              #21
              Thanks Tim, Ver 4.0.1.50 - untested 😪
                #22
                Hello Alex,
                I was a bit late to resume the review and 4.0.1.51 beta has been released. When this was enable this broke a few of the devices as displayed in the attached screen grab of 4.0.1.51.
                  #23
                  Hi Tim,
                  I'll check...
                    #24
                    Little refactoring in the middle of the night hehe 😀
                    Ver 4.0.1.52 - Fix uRADMonitor Local
                      #25
                      I know and appreciate that you put some very long hours and go way onto the nights working on developing, enhancing and all your improving all your apps.. Thanks Alex.
                        #26
                        Hello Alex,
                        Can you please look at Air Quality VOC it is pulling no data.
                        Tim
                          #27
                          Hello Alex,
                          Tim
                          Hi Tim, do you mean Local or Remote, or both?
                          Can you also please post json or any related log.
                          [EDIT]
                          Ok, I guess you mean your Local A3 and the json is in PM, correct?
                            #28
                            [EDIT]
                            Hi Alex,
                            It is both, and I have enable verbose logging (trace) the the VOC (remote) is recorded avg_voc and voc: VOC Ohm is not correct. The local api call with trace enable does not record anything other that the API call.
                            10/24/2021 18:47:15 AK Weather Info [7774] UradMonitor Remote: (uRADMonitor) [B]avg_voc: 3758382[/B]
                            10/24/2021 18:47:16 AK Weather Info [7774] UradMonitor Remote: (uRADMonitor) voc: VOC Ohm
                            {"data":{ "id":"8200000C","type":"8","detector":"SI29BG","voltage":380 ,"cpm":12,"temperature":29.40,"humidity":21.81,"pressure":10 1831,"voc":3760385,"co2":401,"noise":70,"ch2o":0.03,"pm25":0 ,"uptime": 1231569}}
                              #29
                              Yeah, I noticed from json from your PM the VOC value is high, but you reckon it's wrong?
                                #30
                                They are currently not recording any response/value from AK Weather.air_quality_VOC and the value should be represented as response VOC/1,000,000 µg/m3
                                Tim
