Ecowitt WN34L NegativeTemperature not displaying
    Hello,
    I just added a WN34L sensor and while it initially displayed the temperature in HomeSeer, but when I placed the probe in my freezer, the temperature stopped displaying. In the android app, I see the temp correctly at -23.6F
    Click image for larger version  Name:	ecowitt_android.jpg Views:	0 Size:	63.6 KB ID:	1499843
    But in HS I just have a blank value for Temperature Extra [1]
    Click image for larger version  Name:	ecowitt_HS.jpg Views:	0 Size:	23.5 KB ID:	1499844
    Trace Log:
    9/30/2021 8:04:32 PM AK Weather Info [924] Home: Received S_CMD_GW1000_LIVEDATA size 7
    9/30/2021 8:04:32 PM AK Weather Info [924] Home: [016 : 2] 0x63 'TF_USR1' = 6521.5 'Temperature(℃)'; Batt = 1.64V
    9/30/2021 8:04:32 PM AK Weather Info [924] Home: [014 : 1] 0x22 'HUMI1' = 63 'Humidity 1, 0-100%'
    9/30/2021 8:04:32 PM AK Weather Info [924] Home: [011 : 2] 0x1A 'TEMP1' = 15 'Temperature 1(℃)'
    9/30/2021 8:04:32 PM AK Weather Info [924] Home: [008 : 2] 0x09 'RELBARO' = 1012.2 'Relative Barometric (hpa)'
    9/30/2021 8:04:32 PM AK Weather Info [924] Home: [005 : 2] 0x08 'ABSBARO' = 1012.2 'Absolute Barometric (hpa)'
    9/30/2021 8:04:32 PM AK Weather Info [924] Home: [003 : 1] 0x06 'INHUMI' = 49 'Indoor Humidity (%)'
    9/30/2021 8:04:32 PM AK Weather Info [924] Home: [000 : 2] 0x01 'INTEMP' = 24 'Indoor Temperature (℃)'
    And, if I remove it from freezer, it displays correctly again
    Click image for larger version  Name:	ecowitt_HS_2.jpg Views:	0 Size:	10.3 KB ID:	1499845
    Trace: 9/30/2021 8:40:54 PM
    AK Weather Info[924] Home: [016 : 2] 0x63 'TF_USR1' = 15 'Temperature(℃)'; Batt = 1.64V
    And if I put the probe back in, it no longer displays
    Thank You
    When it happens, can you click on the device and take screenshot of Status/Graphics:
Name:	Screenshot 2021-10-01 114538.png
      Probe is in the freezer presently - here's the screenshot
        Thank you. The value looks strange 11770.34 - can you make sense of it?
        [EDIT]
        Also in your original log it doesn't look right: 6521.5
        I may ask Ecowitt developers...
          I guess I know what the problem is - the binary data is signed, not unsigned, that's why negative values become big numbers.
          I'll fix it, but I can't test because I don't have the sensor, Ecowitt sent me new devices, but it may take awhile.
            Apologies, it was late here and I am just back to my computer. Thank you very much - I can test if you want to provide me with an updated PI (or other binary to run) and give you any logging data that might help.
              Ver 4.0.1.34 (BETA) - Ecowitt: support negative readings
              d834758 please test and pay attention to other readings because it's hard to tell from the API document which values should be interpreted as signed and which unsigned
                Excellent - everything looks correct now, thanks! Obviously the app provides a little more precision than you PI but when rounded, everything seems to match..
                Click image for larger version  Name:	ecowitt_android_2.jpg Views:	0 Size:	57.9 KB ID:	1499923
                Click image for larger version  Name:	ecowitt_HS_4.jpg Views:	0 Size:	24.1 KB ID:	1499924
                And here's the trace from a few minutes later, so the values might be slightly off
                10/1/2021 9:55:02 AM AK Weather Info [924] Home: Received S_CMD_GW1000_LIVEDATA size 7
                10/1/2021 9:55:02 AM AK Weather Info [924] Home: [016 : 2] 0x63 'TF_USR1' = -33 'Temperature(℃)'; Batt = 1.6V
                10/1/2021 9:55:02 AM AK Weather Info [924] Home: [014 : 1] 0x22 'HUMI1' = 43 'Humidity 1, 0-100%'
                10/1/2021 9:55:02 AM AK Weather Info [924] Home: [011 : 2] 0x1A 'TEMP1' = 23 'Temperature 1(℃)'
                10/1/2021 9:55:02 AM AK Weather Info [924] Home: [008 : 2] 0x09 'RELBARO' = 1015.7 'Relative Barometric (hpa)'
                10/1/2021 9:55:02 AM AK Weather Info [924] Home: [005 : 2] 0x08 'ABSBARO' = 1015.7 'Absolute Barometric (hpa)'
                10/1/2021 9:55:02 AM AK Weather Info [924] Home: [003 : 1] 0x06 'INHUMI' = 48 'Indoor Humidity (%)'
                10/1/2021 9:55:02 AM AK Weather Info [924] Home: [000 : 2] 0x01 'INTEMP' = 23.1 'Indoor Temperature (℃)'
                  Originally posted by d834758 View Post
                  Obviously the app provides a little more precision than you PI but when rounded, everything seems to match]
                  Precision you can change in the Status/Graphics settings.
                  I set temperature precision to 0 decimal places because I don't believe that 0.1 degrees is of any interest, 1 degree is good enough, and Ecowitt precision is 1 degree anyways.
                    Thank you again.
                    I just set up the local connection as per the post "AmbientWeather and Ecowitt - Local protocol (no Cloud)" and see all of the data except for the WN34L. I do see the data in the log though, so is there something I missed in the configuration?
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) model = GW1000_Pro
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) freq = 915M
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) tf_batt1 = 1.58
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) batt1 = 0
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) tf_ch1 = -27.2
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) humidity1 = 53
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) temp1f = 64.04
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) baromabsin = 29.982
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) baromrelin = 29.982
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) humidityin = 54
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) tempinf = 72.7
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) dateutc = 2021-10-01+16:33:10
                    10/1/2021 12:33:10 PM AK Weather Info [957] Home - Local: (AmbientWeatherLocal) stationtype = GW1000B_V1.6.8
                    Click image for larger version  Name:	ecowitt_HS_5.jpg Views:	0 Size:	51.7 KB ID:	1499991
                      So it's the "tf_ch1" missing? I'll add it.
                      And for this protocol battery (tf_batt1) is available too.
                      I see you changed the precision to 2 decimals, but as I said, it doesn't make sense (unless you calibrate the sensors regularly), and it only makes it more difficult to read the values
                        Correct - the tf_ values. Much appreciated!
                          Ver 4.0.1.35 (BETA)
                          - Added Ecowitt and AmbientWeather Local battery devices
                          - added AQICN exception handlers
                          - refactored Location renaming
                          - improved config screens usability
