When i go to Settings i get an "Access Denied" error
    Originally posted by mda View Post
    i am trying to reconfigure the plugin over MyHS (i am away from home) but when i go to Settings i get an "Access Denied" error (nothing in the HS4 log).
    i can configure any other plugin so i don't think its a general HS4 problem?
    Thanks!
ID:	1500987 Click image for larger version
    Hmm, never seen this. Can you try to get to Settings via main menu (Plugins => AKWeather => Settings)?
    Also, did it work before? Is it consistently not working?
    Also, just try in browser URL: ROOT/AKWeather
    Where ROOT is the "connectedca.homeseer..."
      I did try that too. Could not get it to work. Will try on local network when I get home too
        It is working fine when i am on local network with HS4 server
          https://connectedca.homeseer.com/AKWeather also gives me Access Denied error
          (If this is just happening to me there is no need to solve it… this info is just in case it’s a bug you want to fix for others)
            Thanks for the info, would be interesting to find why???
              Reported to HST Support
