AKWeather NOAA, Metoffice UK.. - 41 providers! PWS local Davis, Ecowitt, AW, Tempest
This is a sticky topic.
    #16
    Ver 4.0.5.40 - Open-Meteo daily forecast: added UV index and precip. probability; Max forecast days increased to 16;
    Transitioned to the 13 km resolution GFS model from the previous 25 km resolution.
      #17
      Ver 4.0.5.52 - Multiple fixes for NOAA Marine
        #18
        Ver 4.0.5.58 - Pass Encoding (UTF8) to ExecuteXML (CanWeather, ControlByWeb_X320M, MeteoAlarmXML, MetOfficeNSWWS, YR)
          #19
          Ver 4.0.5.67
          - Added configurable "For children names - prepend with parent name"
          - SensorPush - Changed max temp/humidity sensors to 16; Add value type to feature name;
            #20
            Ver 4.0.5.72 Added configurable icon folder.
            Just create a new folder next to "C:\Program Files (x86)\HomeSeer HS4\html\images\AKWeather\CanWeather" and duplicate all icons with same names. Icon names are provider specific, please ask if have any questions.
            Click image for larger version  Name:	image.png Views:	0 Size:	30.3 KB ID:	1612635
              #21
              Ver 4.0.5.73
              - OpenMeteo implemented Marine and Weather units
              - shortAddres for GetAddress (for new Location)
                #22
                Ver 4.0.5.75 - Added Precip Probability Night (NOAA1, NOAA2, Accuweather, CanWeather, MetofficeDataPoint, MetofficeSpot)
                  #23
                  Ver 4.0.5.76 - SensorPush - Added Pressures, RSSI and Dewpoints for each sensor.
                    #24
                    Just a note that after updating the installed plugin is still showing the version as 4.0.5.73. No big deal on my end and I am not asking for an update just for this. Just making you aware.
                    Karl S
                    HS4Pro on Windows 10
                    1070 Devices
                    56 Z-Wave Nodes
                    104 Events
                      #25
                      Thanks for letting me know. Please try ver 4.0.5.78 (BETA)
                        #26
                        It shows the version properly. Ecowitt New, Open Weather Map, and Tomorrow IO soar to be working. Will reach out again if I notice anything wrong.
                        I appreciate all the work you put into these, alexbk66!
                        Karl S
                        1070 Devices
                        56 Z-Wave Nodes
                        104 Events
                          #27
                          Ver 4.0.5.80 - Keep coords when select different provider; NOAA2 improve IsDay(), Daily Humidity
                            #28
                            Ver 4.0.5.87 - WAQI (aqicn) added the list of stations in 0.3 degrees distance from current coordinates.
                            Note: for automatic selection (based on current coordinates) - clear the station ID (WAQI Station).
                            Click image for larger version  Name:	image.png Views:	0 Size:	45.3 KB ID:	1621415
                            Click image for larger version  Name:	image.png Views:	0 Size:	64.1 KB ID:	1621416
                              #29
                              Ver 4.0.5.92 (BETA) - Added mDNS auto discovery for WeatherLink Local
                              Discovered devices should appear on the Location config page (I don't own WLL, so it doesn't show):
                                #30
                                Ver 4.0.5.93 (in BETA) - Fully customisable Weather Overview (HTML/PNG)
                                https://forums.homeseer.com/forum/hs...rview-html-png
