My goal is to act on changes to the current weather summary if it has any type of rain. Using the HS UI, the choices are numerous. In fact there are at least 31 possible conditions that imply liquid water falling from the sky (not all use the word "rain"), so building 31 events isn't really practical. Attached shows some of the options. Any advice on the best way to trigger an event if current conditions: weather summary: changes and becomes "any rain"? One option I can see is to have a new key in the field that isn't a literal device string, but encompasses all rain.
BTW, you might think I could use humidity as a proxy (it is likely raining if humidity is high), but that is not very accurate since rain can be born above a low humidity region. Right now it's raining and the humidity is 85%, but many days the humidity has been > 95% with no rain.
Loving rnbWeather so far! I replaced my clumsy web scraping and life is much better.
