When creating a new device for temperature, by default a label is added to all of the temperature devices which overwrites the actual temperature value. (see screenshot) You can easily remove the label in the 'Status/Graphics' settings to show the temperature value correctly. However, I just wanted to post something since it took me a bit to figure out what was going on.
Label overwriting values on creation of new temperature device
Hi [mention]LampenAutomation [/mention], I discovered this yesterday and have written the fix (.25). I am just tidying up a couple of other things and doing checking after which I’ll release the version which will fix existing label issues and not add the label in future.
Originally posted by ferdies View PostHi - it looks like the temperature value is being overwritten by a label "temperature" rather than actual temp value. I am on version .24.
Please see attached.
Thanks.
Originally posted by russr999 View PostI discovered this yesterday and have written the fix (.25). I am just tidying up a couple of other things and doing checking after which I’ll release the version which will fix existing label issues and not add the label in future.
I just installed it, v4.0.0.24 and I'm having that label thing issue. I was wondering when to expect release .25 instead of having to go thru all temperature labels?
One thing I'd like to mention, after setting up the plugin, I never got data until I stopped and restarted the plugin. Did I miss a piece in the documentation and this is normal?
Originally posted by zguy View Post
What a nice plugin! Thanks for that!
I'm looking at your other isse - data not starting until after you stop/start the plugin - Will get back to you on this
Speaking of service, the most accurate for my region, Québec Canada, is https://www.meteomedia.com. In the background the data is coming from https://weathersource.com/products/onpoint-api/. Should you be considering another service, I'd love to have this one available. Even willing to shell the cost of a license if need be.
Another unrelated question, initially, I entered a 2 decimals value for longitude/latitude. In the location setup page, once that is set, it doesn't show. It would be nice to be able to adjust that. I managed to update that to a more precise location with 6 decimals by editing the rnbWeather.ini file. Although the plugin restarted without errors, I have no way to be sure this worked since it is not showing. At this point, I'm assuming the change worked but it would be very nice to see/adjust it in the location page.
Again, thanks for that plugin. I had looked at integrating weather since HS2 and had never succeeded to get something reliable so far.
Hi [mention]zguy [/mention] that’s weird that some of the icons disappeared. I’ll double check but the update shouldn’t have made the icons disappear.
Happy to add weather source into the list of services to be added but can’t say when it will get done yet, only that it will get done. I’ve just checked and it uses an API key so once added, if anybody wanted to use that weather service they would need a valid API key. Pricing looks steep but I may be looking at the wrong or old pricing model.
On the location coordinates, the way I figured it, it is set and forget as it should be a rare rather than. It also use case changing coordinates after you add a location so on this basis it’s unlikely I’ll add a screen to allow you to edit it. For the rare case, editing the ini file is the right/best way to update it. There’s no need to restart the plugin after changing location coordinates as on the next poll it will get the coordinates from the ini. What I could look at doing is to show it in the log (debug log setting) what location coordinates are being used for that location - would this help?
Originally posted by russr999 View PostHi [mention]zguy [/mention] that’s weird that some of the icons disappeared. I’ll double check but the update shouldn’t have made the icons disappear.
Originally posted by russr999 View PostHappy to add weather source into the list of services to be added but can’t say when it will get done yet, only that it will get done. I’ve just checked and it uses an API key so once added, if anybody wanted to use that weather service they would need a valid API key. Pricing looks steep but I may be looking at the wrong or old pricing model.
Originally posted by russr999 View PostOn the location coordinates, the way I figured it, it is set and forget as it should be a rare rather than. It also use case changing coordinates after you add a location so on this basis it’s unlikely I’ll add a screen to allow you to edit it. For the rare case, editing the ini file is the right/best way to update it. There’s no need to restart the plugin after changing location coordinates as on the next poll it will get the coordinates from the ini. What I could look at doing is to show it in the log (debug log setting) what location coordinates are being used for that location - would this help?
