Appreciate if someone can assist:
Object reference not set to an instance of an object
Below is the ini file:
[Support]
Unique=MTkyLjE2OC4xLjEwMC4yMjo1MTowNg==
Original=MTkyLjE2OC4xLjEwMC4yMjo1MTowNg==
[version]
previous=0.0.0.0
current=4.1.0.0
[oweather]
oweatherkey=Wq+NyHpl3oJoZDBThnLxEolVPsESQrE26SlGmkZG1VdGbBu2 OrFVYQ==
oweathercustom=False
oweatherenabled=True
oweatherfiletype=0
oweatheruom=1
[rnbWeather]
SetupComplete=True
[oweather_Locations]
20210715225209=Reston|38.96146|-77.3418
[oweather Devices 20210715225209]
cf20210715225209now=checked|-|-
cf20210715225209weather=checked|-|-
cf20210715225209temp=checked|-|-
[Location_status]
20210715225209=checked
[NOAA]
noaaenabled=True
- Neither OpenWeather nor NOAA are connecting and I did activate them
- I see a number of errors in the log generated by rnbWeather
- I'm not able to add a location for NOAA for some reason. If I enter the location data and click on Save, nothing shows up
Could not load type of field 'System.Net.HttpWebRequest:tlsProvider' (49) due to: Could not resolve type with token 01000030 from typeref (expected class 'Mono.Security.Interface.MonoTlsProvider' in assembly 'Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756') assembly:Mono.Security, Version=4.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756 type:Mono.Security.Interface.MonoTlsProvider membernull)
Openweather (Not Detected) Error reading JToken from JsonReader. Path '', line 0, position 0.
[Support]
[version]
previous=0.0.0.0
current=4.1.0.0
[oweather]
oweatherfiletype=0
oweatheruom=1
[rnbWeather]
SetupComplete=True
[Location_status]
[NOAA]
noaaenabled=True
