Barometric Pressure?
    Did I miss an option for rnbWeather to display the barometric pressure and direction (falling, steady, rising)? NOAA reports it in the "other" plugin.
    rnbWeather looks like a winner so far.
    Here the Davis console and the Meteostick provides this...plus best for a visual is this which I have next to my old Regulator clock...which is set to the NTP server / GPS with PPS signal......this picture is of a replicate...drive wife nuts here as all of my touchscreens show time screen savers and have a bunch of old clocks here (1800's)....
    .you really want local barometric pressure as it varies..
    - Pete
    Auto mator
      Here is a local Davis that I tapped in to ..mostly to compare my weather station to another one...
      http://isurus.mote.org/weather/newpa...s_Weather.html
      It is an old Davis Weather station...thinking that it does report over to NOAA...except the NOAA personal weather station DB is a mess and has never really been fixed....
      Called them one day to move a Manatee that decided to live under my boat dock....The Manatee destroyed the dock and I had to have it rebuilt....along with the sea wall....many many years ago....nice bunch working there....they used a crane boat....never seen one of these....
      Click image for larger version  Name:	FireShot Capture 007 - Current Weather Conditions at New Pass, Sarasota, Florida - isurus.mote.org.png Views:	0 Size:	564.5 KB ID:	1484225Click image for larger version
Name:	FireShot Capture 008 - Index of _weather_newpass - isurus.mote.org.png
      - Pete
      Auto mator
        Per Pete - Yup - I will likely get a Davis. But in the meantime, just use one of the available plugins to access the local NOAA data. Doe this plugin support the barometric pressure from NOAA?
          The website above is very primitive and the data is live. I would use one of Jon00 plugins to screen scrape the date from the website.
          Looking for the old NOAA weather stations db with live data...it is still there someplace....NOAA pools this data....
          Then create a barometric variable in Homeseer. I only know that this would work with WeatherXML...not sure about MBWeather...
          Base today for WeatherXML is NOAA and its been working fine...the data is massaged by the time you get to it...so it is better to get the data from the source that NOAA uses....the older SD pictures from the NOAA satellites were downloaded via SDRadio / RPi and antenna in the attic....they were very fax like looking...new HD NOAA satellites are very nice pictures and you can also download these same way....
          For NOAA satellite images I used to use Unisys weather....now just go directly to satellite image directory and get updated by the minute HD images ....regular or massaged....
          Click image for larger version  Name:	GOES16-CGL-GEOCOLOR-600x600.gif Views:	0 Size:	8.6 KB ID:	1484240
          https://cdn.star.nesdis.noaa.gov/GOE...OR-600x600.gif
          Check out the hxxps://cdn.star.nesdis.noaa.gov/GOES16/
          These are all live saved images every few seconds...
          - Pete
          Auto mator
            Thank you, Pete! Always good info. But I'm still looking for an option in rnbWeather to display the barometric pressure and direction (falling, steady, rising). I want to give the rnbWeather plugin a try until I make a final decision on which way I'll eventually end up.
              Installed it on my new HS4 box which is really not production yet...I see that there Barometrics...air pressure but no numbers....thinking it is coming soon.....
              Looking at the WeatherXML stuff (works fine on HS4) and it does show barometer...
              Current
              Overcast
              Temperature 74° F
              Feels Like 69° F
              Humidity 69%
              Dewpoint 63° F
              Visibility 10 mi
              Barometer 30 in: Steady
              Wind Speed North at 13 mph
              Updated 07/16/2021 01:53 PM
              HomeSeer Updated 07/16/2021 03:00 PM
              - Pete
              Auto mator
                Originally posted by Pete View Post
                ...plus best for a visual is this which I have next to my old Regulator clock.....this picture is of a replica...drive wife nuts here as all of my touchscreens show time screen savers and have a bunch of old clocks here (1800's)....
                Now that's pretty amusing Pete! This is TOTALLY something I would do to the significant other (her)! LOL!!!
