Russ, I see these warnings regularly, though not at any identifiable interval. Is it something I should be concerned about? Something on NOAA's end? The warnings occur throughout every day; the errors are much less common. Thanks.
Frequent warnings & errors in log - NOAA
Hi Wade, it seems to be something on NOAA end in their API. If I can get it, I can request them to check their logs for the correlation I’d but from memory, I need to contact them within a few hours to get them to check.
Let me open an issue on their GitHub and then after that I’ll prob need to get some of these errors as soon as possible after then happen.
I do see it as a problem as it means it didn’t get the data from NOAA this time and like you said, it’s hit and miss when it occurs.
I’m also interested in the error you got as I’ve not seen that before. Is that the first time you’ve seen this error?
I also keep getting this error on all my NOAA locations (These are just a few):
HTML Code:10/14/2021 9:47:50 AM rnbWeather Error NOAA (DFW Airport) Unexpected character encountered while parsing value: >>Response>>> Error An error occurred while processing your request. Reference #102.2d9733b8.1634222870.676c434c 10/14/2021 9:48:27 AM rnbWeather Error NOAA (HNL Airport) Unexpected character encountered while parsing value: >>Response>>> Error An error occurred while processing your request. Reference #102.249733b8.1634222907.90dbcdc 10/14/2021 9:48:18 AM rnbWeather Error NOAA (JNU Airport) Unexpected character encountered while parsing value: >>Response>>> Error An error occurred while processing your request. Reference #102.9f04f17.1634222899.6c396ffd 10/14/2021 9:48:01 AM rnbWeather Error NOAA (SLC Airport) Unexpected character encountered while parsing value: >>Response>>> Error An error occurred while processing your request. Reference #102.359733b8.1634222881.11cb71cd
I'm currently running 4.2.0.0 Plugin and 4.2.5.0 Homeseer
Originally posted by OmegaQuest View PostI also keep getting this error on all my NOAA locations (These are just a few):
-Wade
Can you set rnbbWeather Logging to Trace and leave it run for a bit. After you see this error 2 or 3 times, can you download the log and send it to me to review whats causing this?
Originally posted by Wade View Post
Sure. I've set logging to trace and will watch for that error.
Immediately got a few of these after setting to trace. Any concern? I only ask because it's in red typeface like an error.
Russ, I've only seen the error once since setting logging to trace. Thought I'd go ahead and send you the log as I won't have another chance for several days, but I can't find it. Where does rnbWeather save its log? Not seeing it under /Logs.
To get the log, you will need to go to the HomeSeer log and click export. To reduce the log export, you can specify in the filters the time range to show/export
Originally posted by russr999 View Post
Hi Wade, there is no seperate log. It puts everything into the HomeSeer log. The different log settings in rnbWeather just determine how much detail is logged.
Sent from my iPhone using Tapatalk-Wade
