Wondering if you can add Meteobridge (via IP) and Cumulus (via realtime.txt file) support to your plugin @russr999
Here have two configurations.
1 - old configuration here was a buffered serial cable (purchased from Australia many many years ago) which goes from the console to Cumulus which generates a text file that is read by Jon00's Cumulus script (plugin) and worked with last version (for windows) of WeatherXML
2 - newer configuration using a Meteobridge / Meteostick. I have had the Meteostick for years but never connected it. Originally was going to utilize it with WeatherWX and configured it this way for another HS user a few years back. The Meteobridge works by connecting to a buffered serial cable to console or via the Meteostick.
An IP connection to the Meteobridge provides live data.
Cumulus will work these days with the direct connect to the serial buffered cable and Meteobridge.
