To better help device/feature management if rnbWeather features in HSTouch, you can now specify the location 1 and location 2 you want the devices to go as you create them. This saves having to go back later and assign them to a room/location. It will also make it a little easier when searching HSTouch for you features/devices.
Note: Enter the text [Use Device Group] with the square brackets will allow rnbWeather to assign the device/feature types to what they are. In the example screenshot below, when creating devices/features, rnbWeather woudl create current forecast items as location 1 = rnbWeather and location 2 = Current Forecast etc.
You can use [Use Device Group] for either label 1, label 2 or both.
The locations and which come first can eb foundin HS4 Settings under Custom
