Roy, firstly thanxs for the recent updates, I've noticed that the Daily Forecast - Min Temperature (Night feature only) for either NOAA and Openweather sources seem to always display the value "0" Irregardless of the day, seems to be problem somewhere can you confirm?
Non updating "Min Temperature" (Night feature only)"
Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.19.0
Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.Tags: None
Hi MNB, I've just checked NOAA for your location and I get a Max for Day and a Min for Night correctly. Is it possible for you to delete the Max temperature from the day device, go back to Locations/Devices, and just click save in your Weather Location. This will recreate the feature you just delete. Can you let me know if this now updates correctly? I want to test a theory to see if it's what's causing your problem.
On Openweather, I did have an error - fix is in 4.2.3.0 - which will be released tomorrow.
Rory, I've deleted the Max Temp for Day 1 Forecast and did a Save, but I do not have a Night 0. It seems to take a while for the "Updating Devices and Features...Please wait...: to complete. I currently have the max and min temperature showing 0 degrees for NOAA Day 0 and 1, not sure how long it takes to update is there a means to make it update on demand?
Update I: figured out how to update "POLL NOAA NOW" in the account's devices... my NOAA Connection is showing Offline?
Update II: NOAA is now back Online, but still am getting 0 degrees in the Min Temperature device
Update III: Found the Night devices they were truncated by the 500 displayable devices limit. Still no changeComputer: CUK Intel NUC7i7BNH
Rory, the Min Temp has a value but the Max temp is set to 0 see attached
This is working as expected. Becuase NOAA show both day and night weather, I put the Max in day and the min in night so for Day/Night 0 in your screenshot the max/min is 71/47
does that make sense?
I might just look at showing both in both devices - just need to check my logic to see if the night matches how NOAA show it ie If i show the min from the night device, do NOAA show it the same way os is it the min from the night before? - does that make sense?
Rory, understand the logic, then I would suggest deleting the Min/Max's that will always have a zero value as it serves no purpose to us other than validity check on your part....
- Likes 1
Hi MNB, rnbWeather is updated (v4.2.4.0) to only create the max feature in day features and min feature in night features - this will prevent having max/min in both day and night devices with only one updating in each.
I will still look at the the min to see if I cna add it to the day device - prob easier all round as well.
Rory, many thanxs for your efforts, have downloaded it and will advise, MikeComputer: CUK Intel NUC7i7BNH
