Plugin for Bond Bridge and Smart By Bond devices - Intro / Config / Screenshots
This is a sticky topic.
    #16
    Version 3.0.0.26 - Fixed updating status after executing action
      #17
      Version 3.0.0.27 - Add Bridge ID to device IDs to make them unique between multiple SBB devices.
      Note: it's a breaking change - because HS device addresses changed and HS will duplicae the devices. You have to delete the Bond devices before upgrade.
      Sorry
        #18
        Sorry
        Hi Alex, do you mean all devices including the Bond Bridge and Bond Light devices?
        Plugin's:
          #19
          No, only child devices, I have to append the bridge ID in front, because all SBB devices have same ID=1, and I need unique IDs, i.e. ZZCC63031.4a28142a.MS and ZZCC63031.4a28142a.OpenClose
            #20
            You can just update the plugin version and start the plugin - you will get new devices (with the bridge ID appended to their IDs). Then you can delete the old devices.
              #21
              Thank you Alex, I’ve updated the plugin and deleted the old devices. Something I noticed, the devices all populated with the current statuses which wasn’t happening before.
              Plugin's:
                #22
                Not sure what you mean - before the HS devices didn't reflect the current state in Bond app?
                  #23
                  In prior Bond plugin versions, after the devices were created the device status and icons didn’t show up until after I pressed one of the control buttons for that device.
                  In the latest plugin version I noticed that both the device status and icons were populated at the time the plugin created the child devices.
                  Plugin's:
                    #24
                    I've been fixing issues (thanks to great tester CJMH )...
                      #25
                      Ver. 3.0.0.29 (in BETA) - Implemented Bond Push UDP Protocol (BPUP). HS devices should update status immediately. Now polling may be reduced (60 sec max).
                        #26
                        Ver 3.0.0.30 (in BETA) - Added BPUP logging; Removed start-up update frequency limitation
                          #27
                          Ver 3.0.0.31 - Re-enable Update Timer when BPUP fails; Log HS device state changes (if Do not log commands not checked)
                          Feb-28 1:53:16 AK Bond [1812]: Device: A1.FanDirection Set to -16 (Summer)
                            #28
                            Thanks for all your work on this plugin Alexbk66! It is much appreciated.
                              #29
                              I second that! Thank you for working so hard on this plugin!
                              Plugin's:
                                #30
                                I'm using it myself Wasn't actually going to use it for my home, but I found Bond can control my windows shutters (Somfy clone). So when a hot day is expected - I close the shutters automatically after sunrise. Pretty cool.
                                [EDIT] And open the shutters before sunset if it's expected to be colder tomorrow.
