Plugin for Bond Bridge and Smart By Bond devices - Intro / Config / Screenshots
This is a sticky topic.
    #61
    Originally posted by alexbk66 View Post
    User reported problem upgrading devices from HS3 - I didn't test upgrade myself, so you can either wait, or delete the devices and re-create in HS4 if there are issues.
    https://forums.homeseer.com/forum/hs...ed#post1453317
    None of my HS3 devices functioned after upgrade. I had trouble getting the hub to authorize. Since I wasn’t using Bond devices in events, I just deleted devices and started the plug-in again. It did not auto find the hub, so I entered the IP manually, restarted the hub and all was well.
    HS4 Pro, 4.2.18.9 Windows 10 pro, Supermicro LP Xeon
      #62
      Ver 4.0.0.10 - fixed all issues discussed in https://forums.homeseer.com/forum/hs...4-failed/page2
      Just to recap - Tmds mDNS was broken, other types worked (the best is Apple Bonjour Print Services for Windows), also upgrading HS3 devices fixed, but it's too late for you
        #63
        And BTW, HS4 has problem adding more than three controls per device, it's also fixed in 4.0.0.10 - so you need to verify that you have all controls you need. But safer - install 4.0.0.10 and re-create all devices again. Sorry.
        [EDIT] Alternatively if any controls are missing - you can go to each device setting (Status Graphics) and set explicitly rows and columns for each control (1 based) - having max 3 controls per row - so columns should be 1 - 3.
          #64
          No problem. It’s working. Cost me all of 5 minutes I am having trouble syncing the lights. They are backwards on the two LR fans. On=off and off=on. I’ll play more tonight.
            #65
            You can enable Log in the plugin Settings
              #66
              Ver 4.0.0.17 - Refactored for HS4, if anything is broken - let me know.
              Also, added "Trace" log option for troubleshooting.
                #67
                Ver 4.0.0.24 - Fixed saving manually created devices
                  #68
                  Ver 4.0.0.31 - Downgraded target .NET version to 4.6.2 to support all HST controllers, even very old Linux SEL.
                  Ver 4.0.0.32 (in BETA)- Fixed bug getting stored list of 'actions'. Also made logging BPUP warnings configurable.
                    #69
                    The cheapest option to control Somfy RTS is the RFXtrxUSB-RFX433 with the RFXCOM plug-in.
                    This plug-in supports many 433MHz devices and only blinds but many different blinds, Fan's, Appliance modules, weather sensors, alarm sensors and more.​
                      #70
                      RFXtrxUSB is 109.75 €, but Bond Bridge is $99.00, how is it cheaper? Bond supports many blinds, fans (including built-in Smart-By-Bond devices), fireplaces, etc.
                      It also has infrared (IR) support: The BOND can record and transmit RF (radio frequency) as well as IR (infrared) signals.
                      [EDIT]
                      The Bond Bridge supports devices that are controlled by RF remotes within the radio frequency range of 300-450mhz for RF and IR devices that use 38kHz OOK modulation.​
                      You can check device compatibility here https://bondhome.io/supported-devices/
