New controls created on HS4 restart
    Have had to restart HS4 several times lately and it appears that every time I do additional devices get created .... here is snippet of the last HS log filtered down to the PI and a screen shot of the devices.
    Thoughts?
Name:	2021-02-23 14_27_08-Devices.png
    It looks like only the FanSpeed is duplicated?
      Yes that is correct
        Interesting. And their Address field is the same? Because I check if device exists using the unique Address.
          Yes it does appear that is true.....
          I can dig deeper if you like to see anything specific.
          Chris
          I just rebooted .... here is the log entries in total for Bond and a device list showing a new item created at boot time in log
            Nothing wrong in the log. There's a bug in HS4 when it doesn't find some device by address https://github.com/HomeSeer/Plugin-SDK/issues/161
            Can you please post the device address as string (the image is hard to read) - I will temporary add some workaround for this. Also I may add some extra logging for this device to help troubleshooting the bug.
              Please try ver 4.0.0.11 (BETA) - I remember adding the workaround for this bug (for another plugin) - but not sure if it was included in ver 4.0.0.10
                Can you also post a screenshot of Status/Graphics config page for this device
                  Installed beta - on restart another speed device was created - ZZDF77877.6adba404.FanSpeed - Screen shot to follow
                    Sorry.... does NOT appear that a new one was created on restart
                        Screenshot looks ok. So is it working?
                          Yes, the beta seems to have fixed the issue. No new devices created when re-booted.
                          Thank you,
                          Chris
                            Ah, ok, thank you.
                              Chris
                              Hi Chris, I found the core of the issue. The overlapping StatusGraphics was causing problem in HS. In latest HS 4.1.14.0 they added more checks for that, but I also have to make changes in my plugins.
                              See https://forums.homeseer.com/forum/hs...49#post1462549
                              You see in your screenshot you have range 1 - 3, but also separate entries for 2 and 3?
                              I suggest you delete all FanSpeed (child devices) and start the new plugin 4.0.0.13 - it will create proper StatusGraphics entries.
