Originally posted by CJMH
View Post
However, although AKBond is working (until it doesn't) I see the following messages in the log quite often. I did not see these message in the HS3 version of AKBond. I also had set the polling interval to 0 in the HS3 version and never had any problems with the HS3 version of AKBond running under HS4. Setting the polling interval to zero does not seem to work with the HS4 version or at least it is changed back to 5 seconds or 60 seconds depending on something.
8/11/2021 5:12:05 PM AK Bond Warning [1060] Sofa Fan.Bridge: Since BPUP is working - changing update rate: 60 sec (from 5) 8/11/2021 5:12:00 PM AK Bond Warning [1064] Chriss Fan.Bridge: Since BPUP is not working - changing update rate: 5 sec (from 60) 8/11/2021 5:12:00 PM AK Bond Warning [1063] Project Room Fan.Bridge: Since BPUP is not working - changing update rate: 5 sec (from 60) 8/11/2021 5:12:00 PM AK Bond Warning [1060] Sofa Fan.Bridge: Since BPUP is not working - changing update rate: 5 sec (from 60) 8/11/2021 5:06:14 PM AK Bond Warning [1060] Sofa Fan.Bridge: Since BPUP is working - changing update rate: 60 sec (from 5) 8/11/2021 5:06:14 PM AK Bond Warning [1063] Project Room Fan.Bridge: Since BPUP is working - changing update rate: 60 sec (from 5)
Also at some point when looking at the installed plugins the AKBond status went from "OK" to "Loaded remotely" and I could not disable the AKBond plugin. I had to delete the AKBond plug and reinstall it.
One other thing to note is that I have one (of 7) Bond fan (Gazebo Fan) that is having trouble staying connect to the WiFi. Not sure if that has anything to do wit hit or not.
Any ideas as to what is going on or what to do?
Thanks!
System Profile:
Date/time=8/11/2021 5:35:28 PM EDT Version=HomeSeer HS4 ZEE S2 (Upg from HS3ZS2) Edition 4.1.18.0 (Linux) MONO Version=Mono JIT compiler version 6.12.0.122 (tarball Mon Feb 22 17:44:05 UTC 2021) License=Registered Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json Uptime=0 Days 18 Hours 10 Minutes 10 Seconds Lan IP=192.168.0.103 (HS4PiV5) Device Count=294 Event Count=261 Plugins Enabled=Z-Wave:,Tuya:,Harmony Hub:,AK Bond: Modules/Threads=83 Modules, 51 Threads Available Threads=399 HomeSeer Memory Used=138 Mbytes Plugins Installed=AK Bond 4.0.0.22,Harmony Hub 4.0.13.0,Tuya 4.0.30.0,Z-Wave 3.0.7.0,Z-Wave UI 1.0.0.0 Disk Size=29.72GB
192.168.0.135 IP Address Polling period (default) Bond Push UDP Protocol is active - reduce polling to 60 sec â–¼ 5 sec Delay between messages â–¼ 200 ms Log Trace Add 'control' HS device to each Bond device Enable Bond Push UDP Protocol (recommended) Bond Bridge Project Room Fan.Bridge 192.168.0.187 IP Address Polling period Bond Push UDP Protocol is active - reduce polling to 60 sec â–¼ 60 sec Delay between messages â–¼ 200 ms Log Trace Add 'control' HS device to each Bond device Enable Bond Push UDP Protocol (recommended) Bond Bridge Susans Fan.Bridge 192.168.0.134 IP Address Polling period (default) Bond Push UDP Protocol is active - reduce polling to 60 sec â–¼ 5 sec Delay between messages â–¼ 200 ms Log Trace Add 'control' HS device to each Bond device Enable Bond Push UDP Protocol (recommended) Bond Bridge Chriss Fan.Bridge 192.168.0.176 IP Address Polling period Bond Push UDP Protocol is active - reduce polling to 60 sec â–¼ 60 sec Delay between messages â–¼ 200 ms Log Trace Add 'control' HS device to each Bond device Enable Bond Push UDP Protocol (recommended) Bond Bridge Garden Side Fan.Bridge 192.168.0.129 IP Address Polling period (default) Bond Push UDP Protocol is active - reduce polling to 60 sec â–¼ 5 sec Delay between messages â–¼ 200 ms Log Trace Add 'control' HS device to each Bond device Enable Bond Push UDP Protocol (recommended) Bond Bridge Sofa Fan.Bridge 192.168.0.138 IP Address Polling period Bond Push UDP Protocol is active - reduce polling to 60 sec â–¼ 60 sec Delay between messages â–¼ 200 ms Log Trace Add 'control' HS device to each Bond device Enable Bond Push UDP Protocol (recommended) Bond Bridge Gazebo Fan.Bridge 192.168.0.175 IP Address Polling period (default) â–¼ 5 sec Delay between messages â–¼ 200 ms Log Trace Add 'control' HS device to each Bond device Enable Bond Push UDP Protocol (recommended) Bond Bridge Bond Bridge 192.168.0.155 IP Address Polling period (default) Bond Push UDP Protocol is active - reduce polling to 60 sec â–¼ 5 sec Delay between messages â–¼ 200 ms Log Trace Add 'control' HS device to each Bond device Enable Bond Push UDP Protocol (recommended) Select type of Zeroconf/mDNS discovery (MonoZeroconf) â–¼ Auto Add new device manually if Discovery not working
