every few minutes (404) Niet gevonden. [Status = ProtocolError]
    i just installed a bond device and i keep getting these errors:
    every few minutes De externe server heeft een fout geretourneerd: (404) Niet gevonden. [Status = ProtocolError]
    is there anything i can do what can solve this?
    if you need more information, just let me know
    solved:
    i deleted a ir device in the bond device, plugin did not get that. had to delete device and restart plugin to get it running again.
    i did not had the buttons: turn on/off toggle, they are there now after the plugin restart.
    Is it cloud based?
    This is the translated error : The remote server returned an error: (404) Not found. [Status=ProtocolError]
    Eman.
      Originally posted by Eman View Post
      Is it cloud based?
      Eman.
      No it's not
      it is solved, but i did not want to delete the post.
      If there are more people with this problem, then can search and find this
        Bond made some firmware changes which possibly cause the issue.
        This was already reported https://forums.homeseer.com/forum/hs...he-bond-bridge
        Originally posted by alexbk66 View Post
        When reporting a problem, please try to provide as much info as possible. I.e. system info from Tools => Help.
        Also, there should be error in the HS log. You can also enable Log in the plugin settings and post relevant messages from HS log.
          To be able to fix the issue I need to know the request which caused the error. It should be logged in HS log. Without any info I'm not able to work on this.
