Default 5 second refresh rate does not stay if changed to anything else
    Originally posted by PCK
    Installed v 4.0.0.24, saving the IP works now, thanks.
    However, the default 5 second refresh rate does not stay if changed to anything else. I just noticed this.
    When BPUP (Bond Push UDP Protocol) works - I change update rate to 60 sec because there's no need to poll.
    But I'll check.
Name:	Screenshot 2022-01-18 at 01-48-01 Log.png
ID:	1521486 I discovered it changes itself from 5 seconds to 60 seconds and cycles continuously.
      Ok, I'll check
        I can't reproduce your issue, but I think if you change the update rate from default 5 sec (i.e. to 4 or 6 sec) - it should stop changing
          Ver 4.0.0.25 (BETA) - Separate Update rate for BPUP on and off
            I'll give it a look. Apologies for the delay, work has had me tied up lately.
