After updating bond device en plugin strange warnings
    I just updated the bond device and the plugin itself:
    11-7-2022 18:26:38
    AK Bond
    Warning
    [3977] 'My Bridge': ReceiveUDP unexpected received topic 'devices/2a00c006/actions/TurnOff'
    11-7-2022 18:26:38
    HomeSeer
    Event
    Event Trigger "woonkamer vent rechts aan/uit"
    11-7-2022 18:26:21
    AK Bond
    Warning
    11-7-2022 18:26:20
    HomeSeer
    Event
    11-7-2022 18:26:18
    AK Bond
    Warning
    [3977] 'My Bridge': Since BPUP is working - changing update rate: 60 sec (from 5) (TimerCallback)
    11-7-2022 18:26:11
    AK Bond
    Info
    Running on Windows - using MonoZeroconf
    11-7-2022 18:26:10
    AK Bond
    Warning
    [3977] 'My Bridge': Creating device 'GX': 'beamer' (03cf08cc '')
    11-7-2022 18:26:08
    AK Bond
    Warning
    [3977] 'My Bridge': Creating device 'CF': 'Ceiling fan' (2a00c006 '')
    11-7-2022 18:26:06
    AK Bond
    Warning
    [3977] 'My Bridge': Enabling Bond Push UDP Protocol (BPUP)
    11-7-2022 18:26:38
    AK Bond
    Warning
    Date/time
    11-7-2022 18:29:43 West-Europa (zomertijd)
    Version
    HS4 Pro Edition 4.2.13.0 (Windows)
    License
    Registered
    License ID
    xxxxxx
    MyHS Subscription
    Basic
    MyHS Subscription Backup Interval
    No Backup
    MyHS Subscription Max Cameras
    Confguration File
    C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.json
    In Virtual Machine
    No MFG: hp
    Antivirus
    Windows Defender
    OS
    Microsoft Windows 10 Pro - Work Station
    OS Version
    10.0.19041
    Uptime
    5 Days 21 Hours 55 Minutes 42 Seconds
    User/Access
    default (Admin)
    Lan IP
    192.168.1.140 (DESKTOP-S60875G)
    Client IP
    WAN IP
    77.168.68.36 ()
    Device Count
    2180
    Event Count
    140
    Last Event Ran
    washok : vaatwasser fibaro wisselend uit, Ran at 11-7-2022 18:29:38
    # of unique event scripts
    7
    Connected Speaker Clients
    GROTE SLAAPKAMER (192.168.1.140):[CHROMECAST], WOONKAMER CAST (192.168.1.140):[CHROMECAST ULTRA], WOONKAMER GOOGLE MINI (192.168.1.140):[GOOGLE HOME MINI], GARAGE (192.168.1.140):[CHROMECAST], SHIELD (192.168.1.140):[SHIELD ANDROID TV]
    Processor:
    Intel64 Family 6 Model 158 Stepping 10 at 2,15 GHz
    Modules/Threads
    152 Modules, 178 Threads
    Available Threads
    1023
    System Load
    251 Processes, 20% Load
    Free/Total Memory
    2,04 GBytes / 7,78 GBytes (26% free)
    Free/Total Virtual Memory
    1,75 GBytes / 10,71 GBytes (16% free)
    HomeSeer Memory Used
    205 Mbytes
    Plugin Memory Used
    31 EXE Plug-Ins using 1 Gbytes
    Plugins Installed
    AK Bond 4.0.1.0,AK GoogleCast 4.0.1.4,AK Ikea 4.0.1.6,AK Traccar 4.0.0.44,AK Weather 4.0.2.81,BLDenon 4.0.5.0,BLLAN 2.0.45.0,BLML2HS 2.0.36.0,Caddx 3.4.1.0,DSC Security 3.0.0.56,EasyTrigger 3.0.0.74,IR Plugin 4.0.0.4,JowiHue 4.0.7.2,mcsMQTT 5.24.10.0,Miele 4.0.4.0,Moodo 3P 0.0.0.1,Neato Botvac 4.0.9.1,NetCAM 3.0.0.14,PHEvoHome 3.0.0.41,Plugwise 3.1.0.0,Plugwise Pro 4.0.0.10,Pushover 4.0.7.0,RFXCOM 30.0.0.42,SDJ-SurePet 4.0.1.13,Smart Meter P1 4.0.14.0,Sonos 3.1.0.57,SwitchBot Plugin 4.0.0.0,Telegram 4.0.8.0,Tuya 4.0.37.0,Unifi 4.0.23.0,Worx Landroid 4.0.10.0,Zigbee 4.0.11.0,Z-Wave 3.0.10.0
    Everything works as it should, so that is not a problem. but just curious what is causing this.
    Except for "unexpected received topic" - other warnings are just info. I'll check the "unexpected received topic".
      Please try ver 4.0.1.1 (BETA)
      Latest FW Bond use "long" device IDs (16 chars vs old 8 chars) and for older devices they pad the short ID with 8 zeros. So keep an eye if anything is broken.
        Tried the beta, errors are gone
        Thanks!
          I'm also having some error messages. Just installed the Beta but messages remain. I wasn't sure so I took 5 characters from the token info below:
          Locator.Zeroconf.DeviceLocator: FATAL ResolverListener : Could not load file or assembly 'System.Reactive, Version=5.0.0.0, Culture=neutral, PublicKeyToken=94bc3704cddfc263' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)
          Can't find assembly 'System.Reactive, Version=5.0.0.0, Culture=neutral, PublicKeyToken=94bc*****ddfc263' ()
          KR
          PP
            Please try ver 4.0.1.2 (BETA).
            BTW, the PublicKeyToken is for .NET framework, so it's not secret. And since Bond is using local API - there's no any tokens.
              It worked beautifully my friend!
              Thank you so very much!
              KR
              PP
