Bond Plugin Install Issue
    Hello all
    I'm running HS4.2.15.0 on windows 11, after installing the Bond plugin, it did not show up under the plugins section, restarting Homeseer threw a bunch of errors along the lines of "Cannot load EXE file (possibly missing dependencies) HSPI_AKBond.exe: Unable to load one or more of the requested types"
    Running the bond plugin exe from the install folder gives the errors in the attached
    Any ideas of what may be causing this?
Name:	bond error.jpg
    Please try BETA 4.0.4.3 - to install beta please enable "Show Beta Plugins" on Plugins => Add page.
    In case of any issues please post output from Tools => Help.
      The Beta plugin appears to have done the same, I tried the legacy HS3 version which installed fine, I then removed it and tried the beta, which did not initialize and appear under the plugins section
      This message also shows in the startup log:
      Warning, Error details with EXE HSPI_AKBond.exe: Could not load type 'Utils.ILog' from assembly 'Utils, Version=5.60.93.14549, Culture=neutral, PublicKeyToken=null'.Startup Complete, 1 errors detected, check the log for more information.
      See below outputs from Tools-Help
      Date/time=9/13/2022 9:41:54 AM SA Pacific Standard Time
      Version=HS4 Pro Edition 4.2.15.0 (Windows)
      License=Registered
      Confguration File=C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.json
      In Virtual Machine=No MFG: hewlett-packard
      Antivirus=Webroot SecureAnywhere Windows Defender Webroot SecureAnywhere
      OS=Microsoft Windows 10 Enterprise - Work Station
      OS Version=10.0.19044
      Uptime=0 Days 0 Hours 9 Minutes 47 Seconds
      Lan IP=192.168.2.57 (mhhomeseer)
      Device Count=168
      Event Count=70
      Processor:=Intel64 Family 6 Model 42 Stepping 7 at 1.49 GHz
      Modules/Threads=133 Modules, 72 Threads
      Available Threads=1023
      System Load=201 Processes, 3% Load
      Free/Total Memory=4.08 GBytes / 7.89 GBytes (52% free)
      Free/Total Virtual Memory=4.66 GBytes / 9.77 GBytes (48% free)
      HomeSeer Memory Used=93 Mbytes
      Plugin Memory Used=7 EXE Plug-Ins using 263 Mbytes
      Plugins Installed=BLStat 2.0.87.0,CONCORD 3.1.13.10,EasyTrigger 3.0.0.74,Govee Plugin 4.0.0.0,HSBuddy 3.26.1114.49,Z-Wave 4.0.3.0,Z-Wave Parameters 4.0.55.0
      Date/time=9/13/2022 9:41:57 AM SA Pacific Standard Time
      License=Registered
      License ID=673175
      MyHS Subscription=Basic
      MyHS Subscription Backup Interval=No Backup
      MyHS Subscription Max Cameras=1
      Uptime=0 Days 0 Hours 9 Minutes 48 Seconds
      User/Access=michaelhypolite (Admin)
      WAN IP=208.168.252.183 ()
      Device Count=168
      Event Count=70
      Last Event Ran=Timed Events : Dawn Lights Off, Ran at 9/13/2022 6:00:00 AM
      # of unique event scripts=10
      Modules/Threads=133 Modules, 76 Threads
      System Load=201 Processes, 2% Load
        That's strange message because the Utils.dll version should be 4.0.4.30, it looks like you have some other Utils.dll in your PATH environment.
        May be try deleting C:\Program Files (x86)\HomeSeer HS4\Bin\AKBond folder and re-installing the plugin.
          Just in case - BETA 4.0.4.4 - I renamed Utils.dll to AKUtils.dll
            Great, this version was able to install and activate ok
            Thanks for the quick responses and resolution!
              Great. Please note that this is a temporary version (my common plugin library has some temporary changes for AKShelly plugin). When finished with AKShelly troubleshooting I will post the new AKBond version as well. Shouldn't be any issues for you, just letting you know.
