I'm getting frequent and prolific amount of errors in the log file. Even though the commands to the devices work. Ideas?
Errors filling the log file
It looks like you have update rate set to 5 sec? Normally when Bond Push UDP Protocol (BPUP) is working - the plugin should select lower update frequency (Update Rate when BPUP is enabled).
Can you please post screenshot of your config screen.
Also can post the log from plugin start-up - you can filter log by the plugin (FROM FILTER) and EXPORT the log to a file.
Originally posted by alexbk66 View PostIt looks like you have update rate set to 5 sec? Normally when Bond Push UDP Protocol (BPUP) is working - the plugin should select lower update frequency (Update Rate when BPUP is enabled).
10/5/2022 12:01:04 PM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {BondBridgeInfo} [http://192.168.1.41/v2/sys/version]: The operation has timed out. (tm 5000)
10/5/2022 12:00:59 PM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {State} [http://192.168.1.41/v2/devices/115f7973b0cbe7eb/state]: The operation has timed out. (tm 5000)
10/5/2022 12:00:54 PM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {State} [http://192.168.1.41/v2/devices/98a72444c55bcca9/state]: The operation has timed out. (tm 5000)
10/5/2022 12:00:49 PM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {Response} [http://192.168.1.41/v2/devices]: The operation has timed out. (tm 5000)
10/5/2022 12:00:44 PM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {ExtraBondBridgeInfo} [http://192.168.1.41/v2/bridge]: The operation has timed out. (tm 5000)
10/5/2022 12:00:39 PM
AK Bond
Error
10/5/2022 12:00:34 PM
AK Bond
Warning
[4981] 'The Boxer House': Creating device 'CF': 'Ceiling Fan' (115f7973b0cbe7eb '')
AK Bond
Error
10/5/2022 12:00:32 PM
AK Bond
Info
Running on Linux - using MonoZeroconf
10/5/2022 12:00:29 PM
AK Bond
Warning
[4981] 'The Boxer House': Creating device 'CF': 'Sitting Romm Ceiling Fan' (98a72444c55bcca9 'RCF98v2')
10/5/2022 12:00:28 PM
AK Bond
Error
10/5/2022 12:00:27 PM
AK Bond
Warning
[4981] 'The Boxer House': Enabling Bond Push UDP Protocol (BPUP)
AK Bond
Info
Actions: ["TurnUpLightOn","TurnDownLightOn","TogglePower","TurnOff ","T urnOn","TurnLightOn","TurnLightOff","ToggleLight","DecreaseS peed","IncreaseSpeed","SetSpeed","Summer","Winter","ToggleDi rection","StartDecreasingBrightness","StartIncreasingBrightn ess","Stop","OEMRandom","OEMTimer","IncreaseBrightness","De c reaseBrightness"]
AK Bond
Info
Saved device: [Bond Bridge] ZZFF18596 (192.168.1.41:80)
10/5/2022 12:00:23 PM
AK Bond
Error
10/5/2022 12:00:21 PM
HomeSeer
Plug-In
Finished initializing plug-in AK Bond
HomeSeer
Starting Plug-In
AK Bond loaded in 600 milliseconds
HomeSeer
Starting Plug-In
Plugin AK Bond started successfully in 97 milliseconds
AK Bond
Info
10/5/2022 12:00:21 PM AK Bond ver. 4.0.4.2 (4.0.4.5)
HomeSeer
Starting Plug-In
Initializing plugin AK Bond ...
HomeSeer
Info
Plugin AKBond with instance AK Bond has connected. IP:127.0.0.1:45028
HomeSeer
Plug-In
Interface AK Bond is running as a trial, 8 days remaining.
10/5/2022 12:00:18 PM
AK Bond
Error
10/5/2022 12:00:13 PM
AK Bond
Error
10/5/2022 12:00:10 PM
HomeSeer
Plug-In
Shutting down Plug-In: AK Bond
- Likes 1
Originally posted by alexbk66 View PostHmm, it looks like it never succeeds - was it working before?
10/6/2022 10:10:35 AM
AK Bond
Error
10/6/2022 10:10:30 AM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {State} [http://192.168.1.41/v2/devices/98a72444c55bcca9/state]: The operation has timed out. (tm 5001)
10/6/2022 10:10:25 AM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {Response} [http://192.168.1.41/v2/devices]: The operation has timed out. (tm 5001)
10/6/2022 10:10:20 AM
AK Bond
Error
10/6/2022 10:10:15 AM
AK Bond
Error
10/6/2022 10:10:10 AM
AK Bond
Error
10/6/2022 10:10:05 AM
AK Bond
Error
The plugin is disabled and still logging errors!
10/6/2022 12:46:22 PM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {State} [http://192.168.1.41/v2/devices/115f7973b0cbe7eb/state]: The operation has timed out. (tm 5001)
10/6/2022 12:46:17 PM
AK Bond
Error
10/6/2022 12:46:14 PM
Legacy-Plugin
Z-Wave
Device: Z-Wave Z-Wave Thermostat Temperature Set to 76 (F)
10/6/2022 12:46:12 PM
AK Bond
Error
10/6/2022 12:46:07 PM
AK Bond
Error
10/6/2022 12:46:02 PM
AK Bond
Error
[4981] 'The Boxer House': Execute(sync) {BondBridgeInfo} [http://192.168.1.41/v2/sys/version]: The operation has timed out. (tm 5001)
10/6/2022 12:45:57 PM
AK Bond
Error
10/6/2022 12:45:52 PM
AK Bond
Error
10/6/2022 12:45:47 PM
AK Bond
Error
10/6/2022 12:45:42 PM
AK Bond
Error
10/6/2022 12:45:37 PM
AK Bond
Error
10/6/2022 12:45:32 PM
AK Bond
Error
10/6/2022 12:45:30 PM
Legacy-Plugin
Z-Wave
Device: Z-Wave Z-Wave Thermostat Fan State Set to Fan State 1
10/6/2022 12:45:29 PM
Legacy-Plugin
Z-Wave
Device: Z-Wave Z-Wave Thermostat Operating State Set to Operating State 2
10/6/2022 12:45:27 PM
AK Bond
Error
10/6/2022 12:45:22 PM
AK Bond
Error
10/6/2022 12:45:17 PM
AK Bond
Error
10/6/2022 12:45:12 PM
AK Bond
Error
10/6/2022 12:45:07 PM
AK Bond
Error
10/6/2022 12:45:02 PM
AK Bond
Error
10/6/2022 12:44:57 PM
AK Bond
Error
10/6/2022 12:44:52 PM
AK Bond
Error
- Likes 1
Originally posted by alexbk66 View PostI understand it's working, but did the errors appeared just recently, after update, etc?
7/9/2023 7:55:28 PM
AK Bond
Error
[5002] 'Olibra': Execute(sync)'GET' {State} [http://192.168.1.41/v2/devices/63ccc009be3ac1b0/state]: The operation has timed out. (tm 2001)
7/9/2023 7:55:24 PM
AK Bond
Error
[5002] 'Olibra': Execute(sync)'GET' {Response} [http://192.168.1.41/v2/devices]: The operation has timed out. (tm 2000)
7/9/2023 7:55:20 PM
AK Bond
Error
[5002] 'Olibra': Execute(sync)'GET' {BondBridgeInfo} [http://192.168.1.41/v2/sys/version]: The operation has timed out. (tm 2001)
7/9/2023 7:55:16 PM
AK Bond
Warning
[5002] 'Olibra': BPUP is NOT working - changing update rate: 5 sec (from 45) (TimerCallback) (vc=-1000, )
7/9/2023 7:55:16 PM
AK Bond
Error
[5002] 'Olibra': Execute(sync)'GET' {Response} [http://192.168.1.41/v2/groups]: The operation has timed out. (tm 2001)
7/9/2023 7:55:12 PM
AK Bond
Error
7/9/2023 7:55:08 PM
AK Bond
Error
[5002] 'Olibra': Execute(sync)'GET' {Response} [http://192.168.1.41/v2/devices]: The operation has timed out. (tm 2001)
7/9/2023 7:55:04 PM
AK Bond
Error
7/9/2023 7:55:03 PM
AK Bond
Warning
[5002] 'Olibra': BPUP is working - changing update rate: 45 sec (from 5) (BPUP_Connected True) ()
Code:Date/time=7/9/2023 8:01:16 PM EDT Version=HS4 Standard Edition 4.2.19.0 (Linux) MONO Version=Mono JIT compiler version 6.12.0.182 (tarball Tue Jun 14 22:35:00 UTC 2022) License=Registered Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json Uptime=10 Days 2 Hours 13 Minutes 20 Seconds Lan IP=192.168.1.78 (homeseer-ThinkCentre-M900) Device Count=1146 Event Count=151 Plugins Enabled=drhsIpPlugIn:,IR Plugin:,EasyTrigger:,BLBackup:,NetCam Plugin:,UltraTivo3:,Z-Wave Parameters:,BLLock:,BLLED:,Shark Robot:,MeiKu:,Ring:,Device History:,SonyTV:,SDJ-Health:,Blue-Iris:,ScreenLogic:,JowiHue:,Big5HS4:,Controls Plus:,AK Weather:,AK Bond:,Govee Plugin:,Z-Wave:,UPBSpud: Modules/Threads=179 Modules, 143 Threads Available Threads=799 HomeSeer Memory Used=507 Mbytes Plugins Installed=AK Bond 4.0.5.15,AK GoogleCalendar 4.0.4.3,AK Remootio 4.0.5.0,AK Weather 4.0.5.96,Arduino 4.0.2.20,Big5HS4 3.7.0.0,BLBackup 2.0.63.0,BLLAN 2.0.45.0,BLLED 2.0.1.0,BLLock 3.0.39.0,BLOccupied 2.0.28.0,BLRussound 4.0.5.0,Blue-Iris 3.1.3.33206,Controls Plus 1.3.4.1,Device History 4.4.2.2,drhsIpPlugIn 0.0.0.31,EasyTrigger 3.0.0.78,Govee Plugin 4.0.0.0,IR Plugin 4.0.0.6,JowiHue 4.0.8.7,Manage Voice Devices 3.0.0.0,mcsMQTT 6.8.2.0,MeiKu 3.2.0.11,NetCam Plugin 1.0.0.6,OMNI 3.0.2.23,RaspberryIO 3.0.0.21,Ring 1.0.0.38,rnbWeather 4.4.2.0,ScreenLogic 2.1.5.0,SDJ-Health 3.1.1.4,Shark Robot 1.0.8068.17222,SonyTV 3.0.0.6,Ultra1Wire3 3.0.7364.22993,UltraTivo3 3.0.7956.26531,UPBSpud 3.0.0.54,Zigbee Plus 0.8.0.0,Z-Wave 3.0.11.0,Z-Wave Parameters 4.0.63.0
I'm looking into this - on Linux, there's another thread https://forums.homeseer.com/forum/hs...93#post1624093
Originally posted by alexbk66 View PostI'm looking into this - on Linux, there's another thread https://forums.homeseer.com/forum/hs...93#post1624093
- Likes 1
