I am running HS4 AK Bond on a Linux instance. Recently, I noticed these items in my log file.
I believe I might have installed and subsequently removed a plug in that may have used ZeroConf as well. Any pointers here? I tried removing the Bond plugin and reinstalling.
6/21/2023 9:47:29 AM
AK Bond
Warning
System.NullReferenceException: ### at: Mono.Zeroconf.Providers.AvahiDBus.ServiceBrowser.Browse (System.UInt32 interfaceIndex, Mono.Zeroconf.AddressProtocol addressProtocol, System.String regtype, System.String domain) [0x00032] in :0 at: Mono.Zeroconf.ServiceBrowser.Browse (System.UInt32 interfaceIndex, Mono.Zeroconf.AddressProtocol addressProtocol, System.String regtype, System.String domain) [0x00001] in :0 at: Locator.MonoZeroconf.DeviceLocator._CreateListener (System.Action`1[T] callback, System.Boolean IPv4only) [0x0004b] in :0 at: Locator.MonoZeroconf.DeviceLocator.CreateListener (System.Action`1[T] callback, System.Boolean IPv4only) [0x00009] in :0
AK Bond
Error
Locator.MonoZeroconf.DeviceLocator: 3 FATAL CreateListener.ServiceBrowser: Object reference not set to an instance of an object
6/21/2023 9:47:28 AM
AK Bond
Error
Locator.MonoZeroconf.DeviceLocator: 2 WARN CreateListener.ServiceBrowser: Object reference not set to an instance of an object
AK Bond
Error
Locator.MonoZeroconf.DeviceLocator: 1 WARN CreateListener.ServiceBrowser: No Zeroconf providers could be found or initialized. Necessary daemon may not be running.
AK Bond
Warning
[3081] 'Mikes Bond': Since BPUP is NOT working - changing update rate: 5 sec (from 60) (TimerCallback)
6/21/2023 9:47:12 AM
AK Bond
Warning
[3081] 'Mikes Bond': Since BPUP is working - changing update rate: 60 sec (from 5) (BPUP_Connected True)
6/21/2023 9:47:11 AM
AK Bond
Warning
[3081] 'Mikes Bond': Enabling Bond Push UDP Protocol (BPUP)
AK Bond
Warning
[3082 'Mikes Bond.Light']: changing Address from 'ZZCJ03861.Light' to 'ZZCJ03861.LED'
