Timeout errors (on Linux/Pi?)
    #16
    Originally posted by donlewis98 View Post
    Hi,
    As promised, here is the type of errors in the log.
    Don
    I think wpiman has same issue on Linux. Can you confirm if the problem starts awhile after restarting the plugin, and restarting the plugin fixes the issue (for awhile)?
      #17
      Hi,
      I restarted the PI and this is the only log messages for the first 3 hours.
      No errors.
      Will look again later today.
      Don
Name:	Screenshot 2023-07-08 at 9.38.29 AM.jpg
        #18
        I have been up and running for a while and I haven't seen it.. I'll keep you posted. I created an event to let me know if it see the issue in the log.
        Plug-Ins Enabled:
          #19
          Ok- It happened and my event to detect it fired. I actually shut down and restart the plugin when it happened via an event. Not ideal but for a short term problem it works.
          Don't see anything in the log that happens concurrently. Just kind of looses its marbles...
          Plug-Ins Enabled:
            #20
            On Linux WebClient connection seems to keep open, so eventually there's too many connections open and it stops replying. But that's my guess, I need to investigate.
            Can you please post screenshot of your Settings screen (with "Show Extra Settings" enabled).
              #21
              Just happened again... Reboot worked well...
              ​​​​My settings are below. I thing they reverted to the defaults? I have delays between send to the max, and retries at 6, update rate 10... same issue...
              Intermittent bugs are a bitch to find...
              7/9/2023 12:12:20 PM
              AK Bond
              Warning
              [3081] 'Mikes Bond': Enabling Bond Push UDP Protocol (BPUP)
              7/9/2023 12:12:16 PM
              AK Bond
              Warning
              [3081] 'Mikes Bond': FW: v3.14.1 (Wed Jul 5 14:25:30 UTC 2023)
              7/9/2023 12:12:15 PM
              AK Bond
              Warning
              [3082 'Mikes Bond.Light']: changing Address from 'ZZCJ03861.Light' to 'ZZCJ03861.LED'
              7/9/2023 12:12:09 PM
              HomeSeer
              Plug-In
              Finished initializing plug-in AK Bond
              HomeSeer
              Starting Plug-In
              AK Bond loaded in 623 milliseconds
              HomeSeer
              Starting Plug-In
              Plugin AK Bond started successfully in 284 milliseconds
              AK Bond
              Info
              7/9/2023 12:12:08 PM AK Bond ver. 4.0.5.15 (4.0.5.97)
              HomeSeer
              Starting Plug-In
              Initializing plugin AK Bond ...
              HomeSeer
              Info
              Plugin AKBond with instance AK Bond has connected. IP:127.0.0.1:42674
              7/9/2023 12:10:50 PM
              HomeSeer
              Info
              Plugin AK Bond with ID: AKBond and Instance: has disconnected
              HomeSeer
              Plug-In
              Shutting down Plug-In: AK Bond
              7/9/2023 12:10:49 PM
              HomeSeer
              Info
              Event Trigger "Alarm Bond plugin appears to be stuck"
              AK Bond
              Warning
              [3081] 'Mikes Bond': BPUP is working - changing update rate: 45 sec (from 5) (BPUP_Connected True) ()
              AK Bond
              Error
              [3081] 'Mikes Bond': Execute(sync)'GET' {Response} [[URL="http://192.168.0.203/v2/devices%5D:"]http://192.168.0.203/v2/devices]:[/URL] The operation has timed out. (tm 2001)
              7/9/2023 12:10:45 PM
              AK Bond
              Error
              [3081] 'Mikes Bond': Execute(sync)'GET' {ExtraBondBridgeInfo} [[URL="http://192.168.0.203/v2/bridge%5D:"]http://192.168.0.203/v2/bridge]:[/URL] The operation has timed out. (tm 2000)
              7/9/2023 12:10:41 PM
              AK Bond
              Error
              [3081] 'Mikes Bond': Execute(sync)'GET' {BondBridgeInfo} [[URL="http://192.168.0.203/v2/sys/version%5D:"]http://192.168.0.203/v2/sys/version]:[/URL] The operation has timed out. (tm 2000)
              7/9/2023 12:10:32 PM
              AK Bond
              Warning
              [3081] 'Mikes Bond': BPUP is NOT working - changing update rate: 5 sec (from 45) (TimerCallback) (vc=-1000, )
              AK Bond
              Error
              [3081] 'Mikes Bond': Execute(sync)'GET' {Response} [[URL="http://192.168.0.203/v2/groups%5D:"]http://192.168.0.203/v2/groups]:[/URL] The operation has timed out. (tm 2000)
              7/9/2023 12:10:28 PM
              AK Bond
              Error
              [3081] 'Mikes Bond': Execute(sync)'GET' {State} [[URL="http://192.168.0.203/v2/devices/5135c51f/state%5D:"]http://192.168.0.203/v2/devices/5135c51f/state]:[/URL] The operation has timed out. (tm 2000)​
              Click image for larger version  Name:	Screenshot 2023-07-09 at 12.17.00 PM.png Views:	0 Size:	25.0 KB ID:	1624094
              Plug-Ins Enabled:
                #22
                Yeah, I guess that if restarting the plugin fixes the issue - the problem must be in the plugin, not the Bond...
                  #23
                  FYI, I renamed the thread to Timeout errors on Linux
                    #24
                    Please try 4.0.5.16 (in BETA)
                    Looks like new FW made the Bond very slow (sometimes 10-15sec reply), I need to check with them.
                    Suggested settings:
                      #25
                      Ok. Updated with those settings. I’ll keep
                      you posted.
                      Plug-Ins Enabled:
                        #26
                        And 4.0.5.16 (in BETA)​?
                          #27
                          Yes. 5.16....
                          Almost at 24 hours and no issues....
                          Plug-Ins Enabled:
                            #28
                            About 2 days now..... no issues...
                            Plug-Ins Enabled:
                              #29
                                #30
                                I am going to call this one solved. Nice work.
                                Plug-Ins Enabled:
