Fireplace - How to hold/repeat the RF signal for 'On'?
    Bond Bridge works great with my Somfy shades. Also will turn off my Real Fyre fireplaces, but can't get them to turn On. I usually have to hold the button on my remote for 5-10 seconds to start up. How can I emulate this using the plugin?
    I need more info about your device, please provide the device info - if you click on the device in Plugins => AKBond menu
    Possibly save the screen as pdf.
      Attached. The device is a Real Fyre APK 17.
      https://www.realfyre.com/product/apk-17/
      Here is a document that shows you how to increase the button 'hold time'. It's a little too advanced for me. If you can get to this via the API, can you get to it with your plugin?
      https://global.discourse-cdn.com/sta...1fe8ac5d2.jpeg
      Thanks for your help!
        So you think just sending TurnOn command a few times should work?
          Yea - That second article says "Patch the command TURNON so Reps is 5. Repeating the turn on 5 times quickly?
            I checked the doc you attached - it changes the Bond bridge command to repeat 5 times. I can do what the doco says, but first we'll try just sending 5x TurnOn from the plugin.
              Please try Ver 4.0.5.19 (BETA) - Added configurable number of repeats per Action.
              Not sure if it's gonna work - repeating the command via API is not the same as repeating from the Bridge.
              I also tried the fix you suggested, couldn't get it working, I asked in the Bond Forum https://forum.bondhome.io/t/fireplac...l-command/4141
              To install BETA - enable "Show Beta Plugins" on Plugins => Add page
              Also enable "Show Advanced Settings"
                I guess you already saw this https://forum.bondhome.io/t/need-to-...econds/1059/39
                  Is that saying that it wont work anymore?
                    Did you try Ver 4.0.5.19 (BETA)?
                      opie?
                        This did not seem to work.
                          Please install ver 4.0.5.20 (BETA).
                          Did you set Repeats for TurnOn? Please be a bit more verbose, describe what you tried, what didn't work.
                          And please EXPORT HS log to file - screenshots are difficult to read.
