No longer accessing Bond Device after network problems
    Originally posted by donlewis98 View Post
    ​​I had to have the Bond device get a new DHCP address assigned. Used the BOND App on my iphone to re-join the wifi. BOND works A-OK from the iphone BOND app. Not from HS4. Getting this message: The remote server returned an error: (401) Unauthorized. How doI fix this error? BOND Device is at 192.168.204.19 on the local network and is set as such in the AKBOND settings.
    HS4 4.2.19.0
    AKBOND 4.0.5.18 BETA
    ________
    Date/time=7/24/2023 1:05:21 PM EDT
    Version=HS4 Pro Edition 4.2.19.0 (Linux)
    MONO Version=Mono JIT compiler version 6.8.0.105 (Debian 6.8.0.105+dfsg-3.2 Wed Jun 30 05:34:49 UTC 2021)
    License=Registered
    MyHS Subscription=Lite
    MyHS Subscription Backup Interval=No Backup
    MyHS Subscription Max Cameras=1
    Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
    Uptime=1 Day 16 Hours 30 Minutes 7 Seconds
    User/Access=don@lewisfl.com (Admin)
    Lan IP=192.168.204.7 (homeseer4.int.lewisfl.com)
    Client IP=192.168.204.134 (192.168.204.134)
    WAN IP=71.215.127.206 ()
    Device Count=1023
    Event Count=122
    Last Event Ran=Motion Events : Kitchen Motion, Ran at 7/24/2023 12:45:36 PM
    # of unique event scripts=3
    Connected Speaker Clients=CHROMECAST (127.0.0.1):MASTER BEDROOM SPEAKER, CHROMECAST (127.0.0.1):COMPUTER ROOM SPEAKER, CHROMECAST (127.0.0.1):FAMILY ROOM SPEAKER
    Plugins Enabled=Z-Wave:,Google Nest:,EasyTrigger:,Z-Wave Parameters:,Chromecast:,HSBuddy:,HS4 Internals:,Ring:,TPLinkSmartHome4:,HS MyQ:,AK Bond:
    Modules/Threads=84 Modules, 94 Threads
    Available Threads=798
    HomeSeer Memory Used=319 Mbytes
    Plugins Installed=AK Bond 4.0.5.18,Chromecast 4.0.21.0,EasyTrigger 3.0.0.76,Google Nest 4.0.1.0,HS MyQ 4.0.14.0,HS4 Internals 4.0.5.0,HSBuddy 4.47.619.4,Ring 1.0.0.42,TPLinkSmartHome4 2022.12.30.0,Z-Wave 4.1.2.1,Z-Wave Parameters 4.0.63.0​
    Did you try rebooting the Bridge?
    https://forums.homeseer.com/forum/hs...78#post1448278
    ​The Bridge must be rebooted within 10 minutes of starting the plugin to provide authorisation token. (doesn't matter before or after starting the plugin). This needs to be done only once. If you don't - the Bridge status will be "unauthorised".
    Hello Alex,
    Tried rebooting the bridge multiple times. No success.
    Removed the AKBOND PI, reinstalled, verified IP address of bridge, fixed missing devices in the Events section.
    Working again.
    Thanks.
    Don
