Looking for ideas... I've got a Aeotec Micro Dimmer hooked up to a toggle switch for a bathroom light. To manage the light level I created two events to set Last to appropriate levels. - 9 PM, set Dim to 25 & then Off
- Sunrise + 1 hour, set Dim to 85 & then Off
This way when you switch on the toggle it goes to Last. However I'd like to be able to override this, from the toggle switch. Something like... Toggle on/off/on is X seconds and light goes to On (not longer dimmed).
Doable? I've searched and tried a few various event setup, but haven't crack the nut yet. I would appreciate any guidance you might have.
Maybe there is a better way to set Last as well, put I don't see one...
