HS-TouchDesigner for PI
    Just burning the HS4 beta. But when ( ever? ) will HSDesigner be available for anything other than Windows?
    A PI version ( even Mac ) would be great!. Otherwise at the moment I need a PI and PC 🙁
    Not totally sure that it will ever be available to run on Linux using an Arm / Intel CPU. Guessing.
    That said you can install Ubuntu Linux on an Intel computer and run Oracle Virtual Box on it and install a Windows OS in Virtual box.
    Here using a Windows VB on Linux works fine for me.
    - Pete
    Auto mator
    HSTouch on Intel tabletop tablets - Asus AIO
      I also use virtualbox to run designer. PITA but it allows me to run HSTouch as well and I can test and build from the same point. This is my only Windows machine.
        Yeah I tried windows10 vm on my i7 Mac. It was so slow just moving the mouse pointer I gave up. Went and bought a Nuc though! - so problem solved
