I am contemplating getting the Pi version of HS4. I just need some clarifications please if somebody knows the answers:
1. 5 plugin limit effectively means 5 ecosystems integrated, right? So LIFX + Wemo + Zigbee + Chromecast + Harmony for example, and I won't be able to add HUE now to the system because I have reached the 5 plugin limit, right?
2. Can I get around the problem by using an existing integrated platform like Smartthings? For example, LIFX + Wemo + HUE all go through Smartthings, so when I connect HS4Pi to Smartthings, I can effectively control LIFX + Wemo + HUE without using additional plugins on HS4Pi, right?
3. Done this way, do I get the same amount of control for LIFX, for example (via Smartthings-HS4Pi), compared to connecting directly (i.e LIFX-HS4Pi)?
4. Do the rules engine work the same in the Pi version of HS4 compared to the full version? The main reason to change to HS4 for me is the ease and flexibility of programming rules via GUI. I really don't want to bother with Webcore for ST.
5. Things like Alexa should work with HS4Pi without counting as a "plugin", right?
