Hometroller Zee S2 - HS4 upgrade steps
    I have two Zee S2 systems. I upgraded one from HS3 to HS4 yesterday without issue, following the provided upgrade instructions. Each step completed with results expected, per the instructions, resulting in a successful HS3 to HS4 upgrade.
    Today, I am having problems upgrading my second Zee S2 to HS4. When I proceed to upgrade instruction Step 2: Update System, the Zee status light turns Blue, as expected. However, after about 10 minutes, the web browser page, which is waiting for a response from the Zee, times out. The light on the controller stays blue. It never completes with the results expected per the upgrade instructions. I tried to execute this step again, as the instructions state in case of an update failure, same result - timeout. Two more times yielded the same result.
    If you have experienced this, please let me know if/how you got around it to successfully complete the HS4 upgrade.
    BTW, HS3 is still operational, so nothing was disabled by this upgrade malfunction.
    Thanks in advance...
    Don
    I have the exact same problem. No response yet by Homeseer support.
      Does anyone know where this upgrade document is located now?
      https://helpdesk.homeseer.com/articl...upgrade-to-hs4
        I found this https://docs.homeseer.com/display/HS...Troller+Zee+S2
        But I can't say whether it's the same content
