I have a Zooz ZEN20 connected to my HomeSeer Home Troller running HS4 (HS4 Version 4.1.20 Z-Wave Plugin: 3.0.2.0).
Whenever I select Switch 1, 3, 4 or 5 and turn them on via HS4, Switch 7 also changes state.. This Zooz ZEN20 switch was used to replace a strip plug that became inoperative that was originally located at Node 14.
I did a replacement of the bad node with the new unit and had similar issues. The original firmware was 2.0 and Zooz sent me 2.02 to see if would correct the issue. The firmware installed without reporting any errors.
After I did the replacement the issue was not resolved and Zooz suggested that I perform a Exclude and then Include. This was completed and a new Node 18 was created.
Switches 1 thru 5 properly control the outlets on the ZEN20. Switch 6 and 7 provide status of the two USB ports according to the documentation.
The image below shows the response to turning on Switch 1.
Does anyone have some suggestions on how to correct this issue?
