I'm slowly starting to upgrade all "my" systems to HS4. I started with the one at work that controls the charging of our rechargeable batteries.
It's a HS3-Pi (free) that I've purchased an upgrade to HS4-Pi for. The upgrade process wasn't exactly smooth. I had to reset the HS4 installation once the HS3->HS4 upgrade process was finished, but to my surprise all devices, events and plugins were installed.
HOWEVER:
When I try to adjust anything in the Setup pages, the UI (the webinterface) just locks up. If I pull the plug, or restart using putty, the settings were saved so at least that is working, but it takes too much time having to restart the system after every setting.
Is there something I can do about it?
HOWEVER:
