I have a new HomeSeer HomeTroller Pi that i installed last week. Its working great, talking to my.homeseer.com and Mobile is working as well. I did not change the LINUX admin login information and i cant log into the OS from the TOOLS, LINUX, LINUX TOOLS screen. It says the default login name is homeseer. I did not change the password and the documentation says the default password is hsthsths3 but that does not work. Can someone help?
Default Linux Login and Password HomeSeer HomeTroller Pi
If you didn't change it the password is hsthsths4
edited to correct the password.πββοΈ Support & Customer Service πββοΈ Sales Questions π Shop HomeSeer Productsβ
Ok what is the root password? User name βrootβ and password is what?
Clearly support and engineering has not tied this and as I suspect most users donβt care. Username βHomeseerβ does not work with hsthsths3 or 4. Clearly a bug.... I have a new fresh install as well.
root password is documented in installation guide: https://homeseer.com/guides/HomeSeer-HS4Pi-Guide.pdf
When you register HS4, I believe it's step#5 where you change the Linux login. If you change it then the default will no longer work.πββοΈ Support & Customer Service πββοΈ Sales Questions π Shop HomeSeer Productsβ
Originally posted by cayenne View PostOk what is the root password? User name βrootβ and password is what?
You shouldnt need root access since user homeseer is in the sudoers file.HS4Pro on a Raspberry Pi4
54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
HSTouch Clients: 1 Android
Originally posted by hankli View PostAt any rate, I submitted a help ticket. Support should be able to easily reproduce this problem and look into it.
i have tried remote terminaling in via a ssh app as well as trying through the Linux tool menu in Hometroller. I have tired all logins. User name homeseer pass hsthsths3 and hsthsths4. i have tried homeseerpi as the username, and root as the username. I have tried : root pw = homeseerpi | homeseer pw = hsthsths4. Can not log into Linux, When i first installed it i tried to change the password but it said my passwords did not match and when i tried it again i got no response from the UI, if i use the LINUX drop down change password menu i get no response , it does no say wrong password just does not do anything.....
