Anyone have any tips for me? I have tried 3+ different drives with zero luck... (Eprom is upgraded) regular pi OS boots fine from ALL drives..
HS4PI boot from SSD
After you have powered up your RPI type the following at the command line.
sudo systemctl status homeseer.service
This is just to check if your instance of HS is running or not.
Could you copy/paste the contents of your homeseer.service file here.
If in fact HS isn’t running on boot can you start it manually. Locate the folder where HSConsole.exe resides and launch the following command
sudo mono HSConsole.exe --log
Now try accessing it via you web browser
Originally posted by Bill Brower View PostThis gentlemen has had a lot of success: Andreas Spiess - YouTube
Originally posted by Tesadorn View Post
It boot fine from SSD with ANY other OS I have tried with it... It will NOT boot from SSD with the HS4 image, It finds the SSD then hangs right there... I will post a screen shot...
~Bill
Possibly outline the steps you have taken from the time you have installed the OS and rebooted to the time after you’ve installed HS.
Try apply some logical fault finding procedure to a conclusion before you embark on another.
Originally posted by concordseer View PostOk. So assuming you have installed the OS and rebooted and it boots fine. Then you install HS. Is that correct. Before you attempt to set up any system daemon or reboot could you try launching HS manually as I outlined above.
https://homeseer.com/wp-content/uplo...S4Pi-Guide.pdf
The image is NOOBS-based. I wonder if a NOOBS-based distribution is compatible with re-targeting to an SSD.
Originally posted by zwolfpack View Post
HS4-Pi is only distributed as an SD card image. I think he's saying that it doesn't boot to the OS.
For anyone serious about HS I reckon HS Standard is a minimum for anything exotic like booting from SSD 😂
I’m sure there must be an upgrade path. If not suck it up or go HS Standard or better.
I doubt it with the partition setup on the card. There’s so many new users out there and I doubt they knew what they were buying into. I reckon it’s a case of “you have what you bought” and get on with it.
sudo apt update
sudo apt upgrade
after it finished, then clone to SSD, it will run from SSD. the only thing is that you have to upgrade wiringPi to make little board LED display properly.
Originally posted by PFL View Post
You just need to run:
sudo apt update
sudo apt upgrade
The issue is the version of the Raspbian OS that is on the HS image does not support booting from USB.
Here I'm running Raspbian 64Bit upgraded to Debian 11 64Bit on a Raspberry Pi4 8GB on an Argon one SSD adapter with a Samsung 860 EVO 256GB SATA SSD.
Note: I use this as my main system even though I have an Intel I9 system next to it.
Install your OS first.
Download the HS4 image
Copy the /usr/local/HomeSeer folder from the HST image to your new OS.
Install the HS4 dependencies such as Mono 6, vbnc, flite, Etc..
Navigate to /usr/local/HomeSeer and launch ./go
Roger D
