hs4 troller hung. locked up. reboots not get past re-locked. BLOCKED
    suddenly my hs4 troller is HANGING after this in the log and is unresponsive and reboot does not solve problem.
    HomeSeer Web Control
    geetee
    Search
    Plugins
    V4.1.16.0
    9:54:38 PM
    XXXXX
    XXXXX
    6/6/2021
    Start Date
    9:49 PM
    Start Time
    End Date
    End Time
    Auto Update
    Search Log
    Time
    From
    Type
    Message
    6/6/2021 9:49:50 PM
    HomeSeer
    Startup
    Loading Settings
    6/6/2021 9:49:50 PM
    HomeSeer
    Warning
    HomeSeer was not shut down successfully the previous time it was started.
    6/6/2021 9:49:51 PM
    HomeSeer
    Startup
    Settings Loaded.
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    HomeSeer version 4.1.16.0 Edition: HomeSeer HS4 Pi Hub Starting Now
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    Creating Class Objects...
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    COM port classes started.
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    Application interface class started.
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    Web server class started.
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    E-Mail SEND class started.
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    E-Mail RECEIVE class started.
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    Plug-In Interface class started.
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    Local voice recognition class started.
    6/6/2021 9:49:54 PM
    HomeSeer
    Startup
    Loading configuration file ...
    6/6/2021 9:49:55 PM
    HomeSeer
    Database
    Opening (Mode=Read/Write) up HomeSeer LOG database /tmp/HomeSeerLog.hsd
    6/6/2021 9:49:56 PM
    HomeSeer
    Info
    Loaded 95 Devices.
    6/6/2021 9:49:57 PM
    HomeSeer
    Info
    Loaded 139 Events.
    6/6/2021 9:49:57 PM
    HomeSeer
    Startup
    HomeSeer version is: 4.1.16.0
    6/6/2021 9:49:57 PM
    HomeSeer
    Startup
    Creating Speaker Client Interface Object...
    6/6/2021 9:49:57 PM
    HomeSeer
    Startup
    This version of HomeSeer is registered as a HS4ZEES2_PIHUB version.
    6/6/2021 9:49:57 PM
    HomeSeer
    Web Server
    Local IP address is: 150.233.25.38
    6/6/2021 9:49:57 PM
    HomeSeer
    Web Server
    Web Server started on port 80
    6/6/2021 9:49:57 PM
    HomeSeer
    Startup
    Initializing email, will check server for new email
    6/6/2021 9:49:59 PM
    HomeSeer
    Startup
    Start automation engine...
    6/6/2021 9:49:59 PM
    HomeSeer
    email
    Start checking server for email using Gmail
    6/6/2021 9:49:59 PM
    HomeSeer
    Startup
    Initializing Speaker Client Interface
    6/6/2021 9:49:59 PM
    HomeSeer
    Speech
    Listening for remote speaker connections on port 10401
    6/6/2021 9:49:59 PM
    HomeSeer
    Database
    Opening (Mode=Read/Write) up HomeSeer Energy database /usr/local/HomeSeer/Data/Energy/Energy.hsd
    6/6/2021 9:50:00 PM
    HomeSeer
    Startup
    Updater services starting...
    6/6/2021 9:50:00 PM
    HomeSeer
    Startup
    Starting Find service...
    6/6/2021 9:50:00 PM
    HomeSeer
    Info
    Remote plug-in API interface started on port 10400
    6/6/2021 9:50:00 PM
    HomeSeer
    Startup
    Checking for available plug-ins
    6/6/2021 9:50:00 PM
    HomeSeer
    Plug-In
    Found plug-in: Wemo, version: 4.0.4.0
    6/6/2021 9:50:02 PM
    HomeSeer
    email
    Initializing email, found 10 messages
    6/6/2021 9:51:20 PM
    HomeSeer
    Plug-In
    Found plug-in: Z-Wave, version: 3.0.4.0
    6/6/2021 9:51:25 PM
    HomeSeer
    Plug-In
    Found plug-in: Sonos, version: 3.1.0.53
    6/6/2021 9:51:28 PM
    HomeSeer
    Plug-In
    Found plug-in: CONCORD, version: 3.1.13.10
    6/6/2021 9:51:28 PM
    HomeSeer
    Startup
    Initializing Plug-Ins
    6/6/2021 9:51:30 PM
    HomeSeer
    Info
    Plugin Z-Wave has connected. IP:127.0.0.1:42296
    6/6/2021 9:51:30 PM
    HomeSeer
    Starting Plug-In
    Initializing plugin Z-Wave ...
    6/6/2021 9:51:30 PM
    Legacy-Plugin
    Z-Wave
    InitIO called, plug-in version 3.0.4.0 is being initialized...
    6/6/2021 9:51:31 PM
    Legacy-Plugin
    Z-Wave
    Database: Opening (Mode=Read Only) up HomeSeer database /usr/local/HomeSeer/Data/Z-Wave/Z-Wave2.db
    6/6/2021 9:51:31 PM
    Legacy-Plugin
    Z-Wave
    Loading Z-Wave Network Objects...
    6/6/2021 9:51:31 PM
    Legacy-Plugin
    Z-Wave
    1 total Z-Wave Network Objects loaded.
    6/6/2021 9:51:32 PM
    Legacy-Plugin
    Z-Wave
    Loading Z-Wave Data Objects...
    6/6/2021 9:51:32 PM
    Legacy-Plugin
    Z-Wave
    1 Networks were restored from the data in the database... Building data connections.
    6/6/2021 9:51:32 PM
    Legacy-Plugin
    Z-Wave
    Network E6DC5768 has 25 device data elements.
    6/6/2021 9:51:32 PM
    Legacy-Plugin
    Z-Wave
    25 total Z-Wave Data Objects loaded.
    6/6/2021 9:51:34 PM
    HomeSeer
    Starting Plug-In
    Plugin Z-Wave started successfully in 3666 milliseconds
    6/6/2021 9:51:34 PM
    HomeSeer
    Starting Plug-In
    Z-Wave loaded in 5230 milliseconds
    6/6/2021 9:51:34 PM
    HomeSeer
    Plug-In
    Finished initializing plug-in Z-Wave
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    0 event actions were loaded from HomeSeer.
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    0 event triggers were loaded from HomeSeer.
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    465 Simple AV Control Command Class Control Commands have been loaded successfully.
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    Internal: ============================================================ ==========
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    Internal: ----------------------------------------------------------------------
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    Initializing Z-Wave interface Internal (Internal) on /dev/ttyAMA0
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    Internal: The Z-Wave Command Execution Thread was Started or Restarted.
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    Internal: The Z-Wave API Execution Thread was Started or Restarted.
    6/6/2021 9:51:34 PM
    Legacy-Plugin
    Z-Wave
    Internal: Getting node information from controller...
    6/6/2021 9:51:35 PM
    HomeSeer
    Info
    Plugin CONCORD has connected. IP:127.0.0.1:42300
    6/6/2021 9:51:35 PM
    HomeSeer
    Starting Plug-In
    Initializing plugin CONCORD ...
    6/6/2021 9:51:35 PM
    Legacy-Plugin
    CONCORD Debug
    isLinux = True
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    InitConcord() Concord Vers: 3.1.13.10
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Initializing Concord DB
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Initializing DB Connection: Data Source=/usr/local/HomeSeer/Data/CONCORD/CONCORDDB3.db; Version=3;
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Returned from InitDB: True
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Loading Keypad table
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    LoadKeyPadTable() - filename=/usr/local/HomeSeer/Data/CONCORD/keypadtable.txt
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Loading settings from hspi_Concord.ini
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Users loaded from hspi_Concord.ini
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Retrieving User Data
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Verifying User/Tracking tables
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Checking/Updating DB configuration
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Loading Zone Types
    6/6/2021 9:51:36 PM
    Legacy-Plugin
    CONCORD Info
    Loading Zone Data from Database to memory
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal: Controller firmware version: 2.8
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal: Z-Wave Serial API version: 8
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal: Z-Wave interface node ID: 1, Home ID: E6DC5768
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal: Found 7 Z-Wave nodes in interface node ID 1 (Internal)
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    The interface's security support has been set.
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal Controller chip type is ZW050x.
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal Controller is static lib.
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal There is a SUC/SIS in the network.
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal is the SIS for the network.
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal: ............................................................ ..........
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    Internal: .............................. FINISHED ..............................
    6/6/2021 9:51:37 PM
    Legacy-Plugin
    Z-Wave
    6/6/2021 9:51:40 PM
    Legacy-Plugin
    CONCORD Info
    Validating Zones/Devices
    6/6/2021 9:51:40 PM
    Legacy-Plugin
    CONCORD Info
    Initializing Timers
    6/6/2021 9:51:40 PM
    Legacy-Plugin
    Z-Wave
    6/6/2021 9:51:40 PM
    Legacy-Plugin
    Z-Wave
    STARTUP COMPLETE: All configured interfaces were successfully initialized.
    6/6/2021 9:51:40 PM
    Legacy-Plugin
    Z-Wave
    6/6/2021 9:51:40 PM
    Legacy-Plugin
    CONCORD Info
    Initializing /dev/ttyUSB0
    6/6/2021 9:51:41 PM
    Legacy-Plugin
    CONCORD Info
    Check/Init Triggers
    6/6/2021 9:51:41 PM
    Legacy-Plugin
    CONCORD Info
    Concord Initialization Complete!
    6/6/2021 9:51:41 PM
    Legacy-Plugin
    CONCORD
    6/6/2021 9:51:41 PM
    HomeSeer
    Starting Plug-In
    Plugin CONCORD started successfully in 5394 milliseconds
    6/6/2021 9:51:41 PM
    HomeSeer
    Starting Plug-In
    CONCORD loaded in 7030 milliseconds
    6/6/2021 9:51:41 PM
    HomeSeer
    Plug-In
    Finished initializing plug-in CONCORD
    6/6/2021 9:51:42 PM
    HomeSeer
    Info
    Plugin HSWemo with instance Wemo has connected. IP:127.0.0.1:42304
    6/6/2021 9:51:42 PM
    HomeSeer
    Starting Plug-In
    Initializing plugin Wemo ...
    6/6/2021 9:51:43 PM
    HSWemo
    Info
    HSWemo version 4.0.4.0
    6/6/2021 9:51:43 PM
    HomeSeer
    Starting Plug-In
    Plugin Wemo started successfully in 1148 milliseconds
    6/6/2021 9:51:43 PM
    HomeSeer
    Starting Plug-In
    Wemo loaded in 2416 milliseconds
    6/6/2021 9:51:43 PM
    HomeSeer
    Plug-In
    Finished initializing plug-in Wemo
    6/6/2021 9:51:43 PM
    HomeSeer
    Startup
    HStouch server not started since it is disabled in setup.
    6/6/2021 9:51:43 PM
    HomeSeer
    Startup
    Running the startup script Startup.vb
    6/6/2021 9:51:49 PM
    HomeSeer
    Device Control
    Device: WebSwitch Den 7 Outlet Spare to Off (100) by/from: CAPI Control Handler
    6/6/2021 9:51:49 PM
    HomeSeer
    Device Control
    Device: WebSwitch Den 4 Outlet Spare to Off (100) by/from: CAPI Control Handler
    6/6/2021 9:51:49 PM
    HomeSeer
    Device Control
    Device: WebSwitch Den 5 HP Color LPT to On (0) by/from: CAPI Control Handler
    6/6/2021 9:51:49 PM
    HomeSeer
    Device Control
    Device: WebSwitch Den 6 SlingBox to Off (100) by/from: CAPI Control Handler
    6/6/2021 9:51:49 PM
    HomeSeer
    Device Control
    Device: WebSwitch Den 8 GT Laptop 3 to Off (100) by/from: CAPI Control Handler
    6/6/2021 9:51:49 PM
    HomeSeer
    Device Control
    Device: WebSwitch Den 1 NAS to Off (100) by/from: CAPI Control Handler
    6/6/2021 9:51:49 PM
    HomeSeer
    Device Control
    Device: WebSwitch Den 3 Outlet Spare to Off (100) by/from: CAPI Control Handler
    6/6/2021 9:51:49 PM
    HomeSeer
    Device Control
    Device: WebSwitch Den 2 SecCam Front to On (0) by/from: CAPI Control Handler
    6/6/2021 9:51:53 PM
    Legacy-Plugin
    CONCORD Info
    Panel Control changed to Disarmed by User: Concord Plug-In
    6/6/2021 9:51:54 PM
    Legacy-Plugin
    CONCORD Error
    An unexpected error occurred in the UpdateDB()Connection was closed, statement was terminated function/subroutine: [System.InvalidOperationException: Connection was closed, statement was terminated at System.Data.SQLite.SQLiteDataReader.CheckClosed () [0x0005c] in :0 at System.Data.SQLite.SQLiteDataReader.NextResult () [0x00006] in :0 at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery () [0x0000f] in :0 at (wrapper remoting-invoke-with-check) System.Data.SQLite.SQLiteCommand.ExecuteNonQuery() at HSPI_CONCORD.dbModule.UpdateDB (System.String mySQLText, System.Boolean OpenClose) [0x000ac] in :0 ]
    6/6/2021 9:51:54 PM
    Legacy-Plugin
    CONCORD Error
    UpdateDB - Error with SQL statement = Update Users set userName_field = "Concord Plug-In" ,lastAction_field = 1623045113 ,userNum_field = 255 where userNum_field = 255
    6/6/2021 9:51:54 PM
    Legacy-Plugin
    CONCORD Info
    6/6/2021 9:52:10 PM
    Legacy-Plugin
    CONCORD Info
    6/6/2021 9:52:10 PM
    Legacy-Plugin
    Z-Wave
    Starting Z-Wave Polling for Network E6DC5768...
    |||| hangs here
    I have a backup file on another unit but how do I stop the troller from hanging and then do a manual restore somehow?
    still hangs.....
      Just a thought, there is an error on the concord PI, it can be the cause or the result of the issue. Maybe try to disable that PI? Disable all PI and start one by one?
        Your Concord plugin database is corrupted. Have a look at this post. If you’re still having difficulties head over to the Concord sub forum for more help https://forums.homeseer.com/forum/se...h-errors/page2
          here is boot up hdmi 2 pics showing the issue
