RFXCOM
    RFXCOM
    Has anyone installed RFXCOM on the HS4 (Legacy Plugin). I had it working fine for years and years on the HS3, but I can not seem to get it working on HS4.
    To start, when I set up the receiver part, It stays stuck in "Initializing"
    The, even thought the Transmitter port says online, I dont seem to be able to setup any any of the LifghtwaveRF gear I have. Its like no signal is being sent from the RFXCOM to pair the device
    It does work but there other things you have to consider if especially using a Raspberry Pi...
    Click image for larger version  Name:	RFXCom.png Views:	0 Size:	51.7 KB ID:	1493224
    Don't forget to also check in the : http://[HS4 IP+Port] /deviceutility
    What's your setup?
    Tip : Don't add from old HS3 settings but install it fresh...(start by removing from the updater then manually hunt down and delete its related files from the HS4 root, bin,html...etc folders.)
    Extra : https://www.abelectronics.co.uk/kb/a...aspberry-pi-os and https://www.raspberrypi.org/forums/v...c.php?t=157930
    Eman.
      It works fine for me. There is a dedicated forum to RFXCOM. I suggest you post your question there. The author is very responsive. Please mention the actual device you have. Any logs would also be helpful.
        All sorted, thanks guys, much appreciated.
        I have the RFXtrx module and was setting up a Transmitter and a Receiver, seems you don't setup a Receiver and that must have been confusing the system and causing the Transmitter part not to work.
        The Transmitter works for both input and output devices
