Running :
Version=HS4 Pro Edition 4.2.6.0 (Linux)
MONO Version=Mono JIT compiler version 5.18.0.240 (Debian 5.18.0.240+dfsg-3 Sat Apr 20 05:16:08 UTC 2019)
License=Registered
Confguration File=/usr/local/HomeSeer/Data/HomeSeerData.json
Uptime=1 Day 22 Hours 45 Minutes 0 Seconds
Lan IP=127.0.0.1 (raspberrypi)
Device Count=206
Event Count=10
Plugins Enabled=Tuya:,Life360:
Modules/Threads=70 Modules, 46 Threads
Available Threads=399
HomeSeer Memory Used=92 Mbytes
Plugins Installed=Life360 3.0.0.326,Tuya 4.0.30.0
error when viewing certain events:
Problem parsing HTML: (1437,32) : error : Unable to convert parameter #0 of type `System.Boolean` to type `` {{includefile 'bootstrap/css/page_common.css'}} {{includefile 'bootstrap/js/hs3_ajax_post.js'}} {{includefile 'header.html'}} {{includefile 'navbar.html'}}
{{ev=event refid}} {{isgroupcond=false}} {{isgrpaction=false}}{{if ev.user_note==''}} {{else}} {{end}} {{if event_enabled ev.ev_ref}} {{else}} {{end}}
{{if trig_if_edit refid index trig_group}}
{{if index==0 && trig_group==0}} If {{else}} {{op1=''}} {{op2=''}} {{if index==0}} {{op1='selected'}} {{else}} {{op2='selected'}} {{end}} OR IF AND IF {{end}}
{{else}} {{if index==0 && trig_group==0}}
IF
{{else if index==0}}
OR IF
{{else}}
AND IF
is this an incorrect installation on RPi or something deeper ?
License=Registered
Device Count=206
Event Count=10
- Groups
- {{ev.ev_group.group}}
- {{ev.name}}
IF
OR IF
{{else}}
AND IF
